Opening and Saving Files: xBase Files
1. Opening an xBase File
Use File → Open and choose one of the following formats from the File of type list:
Then specify additional xBase file options:
Encoding Specifies the text encoding for the xBase file: ANSI 8‑bit or ISO/OEM.
xBase records marked as “deleted” are displayed in red. To clear the “deleted” flag in the saved file, remove the red font color from the corresponding worksheet row.
2. Auto‑Resizing Columns
To automatically resize columns when opening xBase files, enable:
Settings → Options → General → Auto‑fit column widths in imported files
(See Settings)
3. Saving an xBase File
Use File → Save and choose one of the following formats from the File of type list:
To mark records as “deleted” in the saved file, format the corresponding worksheet rows using a red font.
Note: After saving a document in a different format, you may need to use File → Reload to refresh the view.
4. Related Topics
GS-Calc *.gsc and ODF *.ods files
Excel (*.xlsx, *.xml) files
PDF files
Text files (*.csv, *.txt, *.tab ...)
Text *.zip archives
GS-Base (*.gsb) files
dBase/Clipper/FoxPro files
SQLite (*.db) files
MySQL (*.sql) files
