GS-Calc and ODF File Format – Compatibility
GS-Calc can use both its private binary file format and the ODF format as native file formats.
2. GS-Calc (*.gsc)
GS-Calc *.gsc files are typically several times smaller than equivalent ODF files. Thanks to specialized compression techniques, the difference can reach hundreds of times or more. Loading and saving operations can also be tens of times faster.
GS-Calc *.gsc files can be very large — they may exceed 4 GB. The only practical limit is that a single worksheet may use up to ~500 GB of RAM when loaded.
GS-Calc files are plain ZIP archives containing several streams: workbook data, images, file lists (with optional encryption), version metadata, and a thumbnail image stored at Thumbnail/thumbnails.png.
If the file is encrypted, both workbook data and all images are encrypted.
To associate the *.gsc file type with GS-Calc in Windows, run GS-Calc as an administrator and use:
Settings > Register GS-Calc *.gsc File Type
To remove the association, use:
Settings > Unregister GS-Calc *.gsc File Type
3. Open Document Format (*.ods)
GS-Calc uses the Open Document Format (ODF) 1.2/1.3 specification, a standard used by several major applications.
Some GS-Calc–specific features cannot be saved in ODF files. When saving, GS-Calc checks which features will be omitted and displays a summary.
Before saving an *.ods file, you can choose whether it should be compatible with Google Sheets or Excel. This is important because dozens of Excel formulas are saved/loaded differently in Google Sheets.
Common differences include:
4. Related Topics
GS-Calc *.gsc and ODF *.ods files
Excel (*.xlsx, *.xml) files
PDF files
Text files (*.csv, *.txt, *.tab ...)
Text *.zip archives
GS-Base (*.gsb) files
dBase/Clipper/FoxPro files
SQLite (*.db) files
MySQL (*.sql) files
