| Inserting images, files in worksheets |
To insert images or files use the Insert > Image / File command.
Images are displayed in their natural size and proportions. If you resize the frame containing a given
image, double-click it to restore the full size of the frame.
Other inserted (only non-executables are allowed) files are displayed as frames with the associated
icons and file metrics. Right-click such an objects for more information or to save/export it as the original file.
