Entering Data: Using Array Formulas
An array formula returns an array of values — numbers, text, Booleans, or errors — instead of a single value. Any non‑array formula becomes an array formula when at least one of its arguments is replaced with a range or an explicit array.
=A1→=A1:A5
=sqrt(E5) + 1→=sqrt(E5) + {1; 2; 3; 4; 5}
=sqrt(E5) + 1→=sqrt(E5:J10) + 1
When a formula argument is expanded into a range or array, the formula evaluates element‑by‑element and returns an array whose dimensions match those of the array arguments.
2. Matching Dimensions
If a formula contains multiple array or range arguments, all of them must have identical dimensions — the same number of rows and columns.
Correct:
=sqrt(E5:F6) + {1, 2; 3, 4}
Incorrect (returns #VALUE!):
=sqrt(E5:F6) + {1, 2}
The returned array always matches the dimensions of the array arguments. If any argument has mismatched dimensions, the entire formula produces a #VALUE! error.
3. Typical Uses
Array formulas are useful for generating sequences (e.g., chart data), performing element‑wise operations, or simplifying complex logical and arithmetic expressions.
Counting values in ranges
Count numbers in A1:B100 that are either:
=sum(((A1:B100 > 100)*(A1:B100 < 200) + (A1:B100 > 250)*(A1:B100 < 300)))
This works because logical comparisons return arrays of 0s and 1s, and multiplication acts as a logical AND while addition acts as a logical OR.
Summing values that meet conditions
=sum(((A1:B100 > 100)*(A1:B100 < 200) + (A1:B100 > 250)*(A1:B100 < 300)) * A1:B100)
The conditional mask is multiplied element‑wise by the numeric range, producing an array of values that meet the conditions.
Converting errors to empty strings
=if(isError(b1:c5), if(errorType(b1:c5)=0, "", ""), b1:c5)
Note: When ranges are used, all if() arguments must have identical dimensions.
Summing values while ignoring errors
=sum(if(isError(b1:c5), errorType(b1:c5)=0, b1:c5))
Here, errorType() is used to distinguish real errors from non‑errors (errorType = 0). Only valid numeric values are included in the final sum.
