Enabling Scripting
To use Python scripting, you must have the Python package installed. Enabling Python scripting requires the same configuration steps as using Python UDF functions and formulas. Please refer to Installing Python and integrating it with GS-Calc for detailed instructions.
Creating Scripts
You can create scripts as global scripts, which are saved in the program settings and available to all workbooks, or as local scripts stored within a specific GS-Calc workbook, which are only available when that workbook is open.
To create these scripts, use the File > Application Scripts or File > Database Scripts commands.
The "Scripts" dialog box allows you to organize your scripts into subfolders, as well as copy, import, or export them.
View a sample "Scripts" dialog screen.
Notes:
- If a global script is executed while no workbook is open, it should begin with one of the application Open(...) or New(..) functions.
- If a workbook is already loaded, an executed script (whether global or local) automatically refers to that active workbook. Using the Open(...) functions with the same workbook path will have no effect.
- Backslashes used in script text, primarily within file path parameters, must always be doubled. For example:
f:\\my_folder\\file01.gsc.
GS-Calc Functions Available in Scripts
XBaseParams
setFormat(str format) -> bool / getFormat() -> str
A string specifying the xBase file format:
- dbaseIII
- dbaseIV
- clipper
- foxpro
Example:
xBaseParams = gscalc.CreateXBaseParams();
xBaseParams.setFormat("dbaseIV");
setEncoding(str encoding) -> bool / getEncoding() -> str
A string specifying the character encoding in the xBase file:
- windows
- dos
Example:
xBaseParams.setEncoding("dos");
GetFieldCount()
Returns the number of defined database fields.
Example:
xBaseParams.AddField("name", "C", 40, 0);
counter = xBaseParams.GetFieldCount();
SetField(int index, str name, str type, int length, int decimals) -> bool
AddField(str name, str type, int length, int decimals) -> bool
InsertField(int index, str name, str type, int length, int decimals) -> bool
Updates the name and type of an existing database field.
index
name
type
- C - character field
- N - numeric field
- F - numeric field
- L - logical field
- D - date field
- M - memo field
length
The length of other fields are fixed and can't be changed.
decimals
Example:
xBaseParams.AddField("item", "C", 40, 0);
xBaseParams.AddField("price", "N", 5, 2);
xBaseParams.SetField(1, "item", "C", 50, 0);
GetFieldName(int index) -> str
Returns the name of a given database field.
index
Example:
name = GetFieldName(1); # returns "name"
GetFieldType(int index) -> str
Returns the type of a given database field.
index
Example:
name = GetFieldType(1); # returns "C"
GetFieldLength(int index) -> int
Returns the length of a given database field.
index
Example:
name = GetFieldLength(1); # returns 40
GetFieldDecimals(int index) -> int
Returns the length of a given numeric ("N") database field.
index
Example:
DeleteField(int index) -> bool
Deletes a given database field.
index
Example:
xBaseParams.AddField("first_name", "C", 40, 0);
xBaseParams.AddField("last_name", "C", 40, 0);
xBaseParams.AddField("street", "C", 40, 0);
xBaseParams.AddField("city", "C", 40, 0);
name = DeleteField(3);
TextParams
setSeparator(str separator) -> None / getSeparator() -> str
Specifies a character separating columns in a text file.
Example:
textParams1 = gscalc.CreateTextParams();
textParams1.setSeparator("\t"); # tab-separated values
textParams2 = gscalc.CreateTextParams();
textParams2.setSeparator(","); # comma-separated values
A string specifying the character encoding in the text file:
- utf8
- utf16
- windows
- dos
Example:
textParams = gscalc.CreateTextParams();
textParams.setEncoding("utf8");
setQuotingSymbol(str symbol) -> None / getQuotingSymbol() -> str
Specifies a character used to quote values containing column/value separators. The inner quoting symbols are doubled.
Example:
textParams.setQuotingSymbol("\"");
setLoadNumbers(bool value) -> None / getLoadNumbers() -> bool
A logical value specifying whether strings representing unformatted numbers should be converted to numbers. If the value is set to false, a text file will be open/saved faster and all worksheet cells will be text cells.
Example:
textParams = gscalc.CreateTextParams(); textParams.setLoadNumbers(True);
setLoadNumbers(bool value) -> None / getLoadFmtNumbers() -> bool
A logical value specifying whether strings representing formatted numbers should be converted to numbers. If the value is set to false, a text file will be open/saved faster and formatted numbers will become text cells.
Example:
textParams = gscalc.CreateTextParams(); textParams.setLoadFmtNumbers(True);
setLoadDates(bool value) -> None / getLoadDates() -> bool
A logical value specifying whether strings representing date/time values
should be converted to date serial numbers. If the value is set to false, a text
file will be open/saved faster and date strings will become text cells.
If the date data is to be sorted correctly, it must be converted to date serial
numbers.
Example:
textParams = gscalc.CreateTextParams(); textParams.setLoadDates(False);
setLoadDateStyles(bool value) -> None / getLoadDateStyles() -> bool
A logical value specifying whether styles of the date/time values converted to date serial numbers should be preserved in the opened worksheet. If the value is set to false, cells containing date serial numbers will be displaying them as numbers.
Example:
textParams = gscalc.CreateTextParams(); textParams.setLoadDateStyles(False);
setParsingMode(int parsing) -> bool / getParsingMode() -> int
A value specifying if and how possible formulas should be parsed when opening a text file:
- 1 - no parsing; possible formula strings will become text cells
- 2 - parsing GS-Calc 3.x-6.x formulas
- 3 - parsing GS-Calc 7.x-x.x formulas
Example:
textParams = gscalc.CreateTextParams(); textParams.setParsingMode(3);
setColumnWidths(str columnWidths) -> bool / getColumnWidths() -> str
A string specifying fixed column/value widths in the text file. Setting this value overwrites previously defined column/value separator. If a text file line contains more characters than the specified widths, the remaining ones will be forming subsequent max-1024-character fields.
Example:
textParams.setColumnWidths("10, 30, 15, 20");
setSaveFmtNumbers(bool value) -> None / getSaveFmtNumbers() -> bool
A logical value specifying whether numbers from formatted cells should be saved as formatted numbers or as generic non-formatted numbers (e.g. 1,123.10 vs 1123.1).
Example:
textParams = gscalc.CreateTextParams(); textParams.setSaveFmtNumbers(False);
setSaveFmtNumbers(bool value) -> None / getSaveFmtDates() -> bool
A logical value specifying whether formatted dates (serial numbers and generic date/time strings) should be saved as the resulting formatted strings.
Example:
textParams = gscalc.CreateTextParams(); textParams.setSaveFmtDates(True);
setSaveFormulaValues(bool value) -> None / getSaveFormulaValues() -> bool
A logical value specifying whether formulas values should be saved in a text file. If it's set to "false", the formulas themselves will be saved instead.
Example:
textParams = gscalc.CreateTextParams(); textParams.setSaveFormulaValues(False);
setAutoFitColumns(bool value) -> None / getAutoFitColumns() -> bool
A logical value specifying whether after opening a given file columns should be automatically resized to fit their contents. Note: specifying 1/True will result in additional calculations after opening that file which may the entire opening process slightly longer.
Example:
textParams = gscalc.CreateTextParams(); textParams.setAutoFitColumns(False);
MergeParams
A set of parameters used by rows-merging functions.
setPath(str path) -> None / getPath() -> str
Specifies a file(s) with records to merge. The path can contain a file name with wildcard (*, ?) characters, enabling you to merge certain files from a given folder or all files from that folder.
setTable(str table) -> None / getTable() -> str
A string specifying the table with records to merge (for file formats capable of storing multiple tables).
If it's null/empty string, the default/active table is used.setMasterField(int field) -> None / getMasterField() -> int
setSlaveField(int field) -> None / getSlaveField() -> int
setMergeType(int type) -> None / getMergeType() -> int
setFieldNames(bool val) -> None / getFieldNames() -> bool
Specifies whether merged tables contain field/column names in the 1st row (which are then excluded from merging). 1/0, True/False
Default: 0setMatchFieldNames(bool val) -> None / getMatchFieldNames() -> bool
A logical value specifying whether cells/fields from the merged table should be added to these columns where names in the first row in both tables match.
Default: 0setIgnoreEmpty(bool val) -> None / getIgnoreEmpty() -> bool
setEnableUndo(bool val) -> None / getEnableUndo() -> bool
A logical value specifying whether the Undo action should be possible.
For mass rows merging it pays off to turn this option off to save memory.
Default: 0
Example:
mergeParams = gscalc.CreateMergeParams();
mergeParams.setPath("e:\\data_files\\*.gsc");
mergeParams.setTable("customers");
mergeParams.setTable("pivot table reports\\data");
mergeParams.setFieldNames(1);
mergeParams.setMatchFieldNames(0);
mergeParams.setEnableUndo(0);
FormatParams
setDataStyleName(str name) -> bool / getDataStyleName() -> str
A string specifying the predefined data style name:
- Default
- General
- Currency
- Accounting
- Date
- Time
- Date/Time
- Fraction
- Percentage
- Scientific
- Custom
Example:
wbook = gscalc.ActiveWorkbook();
wsheet = wbook.GetActiveWorksheet();
formatParams = wsheet.CreateFormatParams();
formatParams.setDataStyleName("Currency");
SetGeneralNumberFormat(str decimals, BYTE zeroes, bool brackets, bool inRed, bool separators, int scaling) -> bool
In addition to setting the value of the dataStyleName
property, this function enables you to modify the default options for the selected data style.
decimals
The number of decimal places. This can be "auto" or any number from 0 to 14.
Default value: "auto"
zeroes
The number of leading zeroes. This can be any number from 0 to 14.
Default value: 1
brackets
A logical value specifying whether negative numbers should be enclosed in brackets.
Default value: False
inRed
A logical value specifying whether negative numbers should be displayed in red.
separators
A logical value specifying whether thousand separators should be used.
scaling
The display factor as a power of 1000. This can be any number from 0 to 5.
Default value: 0
Example:
formatParams.SetGeneralNumberFormat(4, 1, False, False, False, 0);
wsheet.setSelectedRange("d4");
wsheet.SetCellFormat(formatParams);
SetCurrencyFormat(str decimals, str position, str symbol, bool brackets, bool inRed, int scaling) -> bool
decimals
Default value: "auto" (=2)
position
A string specifying the position of the currency symbol:
- "$1.1"
- "$ 1.1"
- "1.1$"
- "1.1 $"
symbol
A string specifying the currency symbol.
Default value: "$"
brackets
inRed
scaling
Default value: 0
Example:
formatParams.SetCurrencyFormat(0, "$1.1", "$", False, False, 0);
SetAccountingFormat(str decimals, str symbol, int scaling) -> bool
decimals
symbol
Default value: "$"
scaling
Default value: 0
Example:
formatParams.SetAccountingFormat(0, "$", 0);
SetDateFormat(str pattern, bool systemOrder) -> bool
pattern
A string specifying the date format:
"m/d/yyyy", "mm/dd/yyyy", "m/d/yy", "mm/dd/yy", "m/d", "mm/yy", "mmm-d", "mmm-d-yyyy", "mmm-d-yy"
"mmmm d, yyyy", "dddd, mmmm dd, yyyy".
Default value: "m/d/yyyy"
systemOrder
A logical value specifying whether day-month display order should be determined by the current system settings.
Default value: True
Example:
formatParams.SetDateFormat("m/d", True);
SetTimeFormat(str pattern) -> bool
pattern
"h:mm", "h:mm AM/PM", "hh:mm", "hh:mm AM/PM", "h:mm:ss", "h:mm:ss AM/PM", "hh:mm:ss",
"hh:mm:ss AM/PM", "[m]:ss.00", "[h]:mm:ss", "[d] hh:mm"
Default value: "h:mm"
Example:
formatParams.SetTimeFormat("hh:mm AM/PM");
SetDateTimeFormat(str datePattern, str timePattern, bool systemOrder, bool timeFirst) -> bool
The meaning of first three arguments is the same as in SetDateFormat
and SetTimeFormat methods listed above.
timeFirst
A logical value specifying whether the time string should precede the date string.
Example:
formatParams.SetDateTimeFormat("m/d","hh:mm AM/PM", True, False);
SetPercentFormat(str decimals, int scaling) -> bool
decimals
scaling
Default value: 0
Example:
formatParams.SetPercentFormat(0, 0);
SetFractionFormat(long denominator, bool digits) -> bool
denominator
If digits is True, this argument specifies the fixed number of denominator
digits.
If digits is False, this argument specifies the fixed denominator value.
Default value: digits: False, denominator: 1
Example:
formatParams.SetFractionFormat(2, False);
SetScientificFormat(str decimals, const str exponent) -> bool
decimals
The number of decimal places. This can be "auto" or any number between 0 and 14.
exponent
The value of the exponent. This can be "auto" or any number between -99 and 99.
Example:
formatParams.SetScientificFormat("auto", 12);
setFontName(str name) -> bool / getFontName() -> str
A string specifying the font name. To specify the default font name, use an empty string.
Example:
formatParams.setFontName("Tahoma");
setFontSize(int size) -> bool / getFontSize() -> int
The size of the font in points. To specify the default size, use zero.
Example:
formatParams.setFontSize(8);
setLanguage(str language) -> bool / getLanguage() -> str
A string specifying the language related to the font. This is a standard language
code typically consisting of the country-language pair, eg:
en-US, en-GB, en-AU, de-DE, de-AU, es-ES, pl-PL, ru-RU etc.
If the submitted string is invalid, it'll default to en-US.
Example:
formatParams.setLanguage("en-GB");
setBoldFont(bool bold) -> bool / getBoldFont() -> bool
Toggles the "bold" font attribute on/off.
Example:
formatParams.setBoldFont(True);
setItalicFont(bool italic) -> bool / getItalicFont() -> bool
Toggles the "italic" font attribute on/off.
Example:
formatParams.setItalicFont(True);
setUnderlineFont(bool uline) -> bool / getUnderlineFont() -> bool
Toggles the "underline" font attribute on/off.
Example:
formatParams.setUnderlineFont(True);
setStrikeoutFont(bool sline) -> bool / getStrikeoutFont() -> bool
Toggles the "strikeout" font attribute on/off.
Example:
formatParams.setStrikeoutFont(True);
setFontColor(str color) -> bool / getFontColor() -> str
Specifies the font color. Accepted values are: the default system "auto" color,
predefined color names and strings representing 3-byte RGB color values using the hex notation.
The predefined values include: "black", "maroon", "green", "olive", "navy", "purple", "teal",
"gray", "silver", "red", "lime", "yellow", "blue", "fuchsia", "aqua", "white".
Example:
formatParams.setFontColor("#FF0000");
formatParams.setFontColor("green");
formatParams.setFontColor("auto");
setHorzAlignment(str horzAlign) -> bool / getHorzAlignment() -> str
Specifies the horizontal text alignment in cells. Accepted values are the following strings:
- left
- center
- right
- default
Example:
formatParams.setHorzAlignment("center");
setVertAlignment(str vertAlign) -> bool / getVertAlignment() -> str
Specifies the vertical text alignment in cells. Accepted values are the following strings:
- top
- center
- bottom
- base-line
- default
Example:
formatParams.setVertAlignment("center");
setHorzIndent(int indent) -> bool / getHorzIndent() -> int
Specifies the horizontal text indent in cells. Accepted values are between 0 and 255. The default value is 4.
Example:
formatParams.setHorzIndent(4);
setVertIndent(int indent) -> bool / getVertIndent() -> int
Specifies the vertical text indent in cells. Accepted values are between 0 and 255. The default value is 2.
Example:
formatParams.setVertIndent(1);
setWrapText(bool value) -> bool / getWrapText() -> bool
A logical value that toggles wrapping text in cells on/off. Setting this property to True automatically sets the shrinkText property to False.
Example:
formatParams.setWrapText(True);
setShrinkText(bool value) -> bool / getShrinkText() -> bool
A logical value that toggles shrinking text that overflows the width of the cells on/off. Setting this property to True automatically sets the wrapText property to False.
Example:
formatParams.setShrinkText(True);
setTextRotation(int rotation) -> bool / getTextRotation() -> int
Specifies the rotation of the text in cells. Acceptable values are from -90 to 90 degrees.
Example:
formatParams.setTextRotation(25);
setHideFormula(bool value) -> bool / getHideFormula() -> bool
A logical value that toggles hiding formulas on/off.
Example:
formatParams.setHideFormula(True);
setProtectedCell(bool value) -> bool / getProtectedCell() -> bool
A logical value that toggles cell protection on/off.
Example:
formatParams.setProtectedCell(True);
setPrintedCell(bool value) -> bool / getPrintedCell() -> bool
A logical value that toggles printing cell contents on/off.
Example:
formatParams.setPrintedCell(True);
setBorderStyle(str style) -> bool / getBorderStyle() -> str
Specifies the cell border style. The following style names are accepted:
- none
- solid
- dot
- dash
- dash-dot
- dash-dot-dot
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); formatParams = wsheet.CreateFormatParams(); formatParams.setBorderColor("green"); formatParams.setBorderPosition(15); formatParams.setBorderStyle("solid"); formatParams.setBorderWidth(1); formatParams.setBorderDoubleLine(True); wsheet.setSelectedRange("d4"); wsheet.SetCellFormat(formatParams);setBorderWidth(int width) -> bool / getBorderWidth() -> int
Specifies the cell border width. Accepted values are from 1 to 16 logical pixels.
Example:
setBorderDoubleLine(bool doubleLine) -> bool / getBorderDoubleLine() -> bool
A logical value that toggles displaying double borders.
Example:
setBorderColor(str color) -> bool / getBorderColor() -> st
Specifies the cell border color. Accepted values are: the default system "auto" color,
Example:
setBorderPosition(int pos) -> bool / getBorderPosition() -> int
Specifies the cell border color. The following numeric values and their combinations are accepted:
- 0 - removes all borders
- 1 - top
- 2 - bottom
- 4 - left
- 8 - right
- 16 - diagonal left
- 32 - diagonal right
- 64 - borders around a range of cells
Example:
setBkgColor(str color) -> bool / getBkgColor() -> str
Specifies the cell background color. Accepted values are: the default system "auto" color,
Example:
formatParams.setBkgColor("#FF0000");
formatParams.setBkgColor("green");
formatParams.setBkgColor("auto");
setBkgImageName(str name) -> bool / getBkgImageName() -> str
Specifies the cell background image. The name must represent an image available via the workbook list of images (see: "Cell Format > Background > Images").
Example:
formatParams.setBkgImageName("blue-sphere.png");
formatParams.setBkgImageOpacity(100);
formatParams.setBkgImageHorzPos("left");
formatParams.setBkgImageVertPos("center");
setBkgImageRepeat(str repeat) -> bool / getBkgImageRepeat() -> str
Specifies how the cell background image should be displayed within the cell. The following text string values are accepted:
- default - use original image size
- repeat - use original image size repeating the image within the whole cell
- stretch - stretch the image to fit it to the cell size
Example:
formatParams.setBkgImageRepeat("repeat");
setBkgImageHorzPos(str horzPos) -> bool / getBkgImageHorzPos() -> str
Specifies the horizontal position of the cell background image. The following text string values are accepted:
- left
- center
- right
Example:
formatParams.setBkgImageHorzPos("right");
setBkgImageVertPos(str vertPos) -> bool / getBkgImageVertPos() -> str
Specifies the vertical position of the cell background image. The following text string values are accepted:
- top
- center
- bottom
Example:
formatParams.setBkgImageVertPos("top");
setBkgImageOpacity(int opacity) -> bool / getBkgImageOpacity() -> int
Specifies the cell background image opacity. This is a numeric value between 0 (a fully transparent image) to 100 (a fully opaque image).
Example:
formatParams.setBkgImageOpacity(70);
Reset() -> None
Resets the FormatParams object and initiates it with default or empty attributes.
When using such an object with the formatting method of the Worksheet object, only
submitting explicitly a given FormatParams property triggers a corresponding formatting
action. For example, the following code:
wsheet.setSelectedRange("b10:b20");
is the equivalent of clicking the "Bold" toolbar button, then the "Italic" format button. If the following code reuses the same FormatParams object without resetting:
it is the equivalent of clicking the "Bold" toolbar button, then the "Italic" format button, then choosing the "Currency" style.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); formatParams = wsheet.CreateFormatParams(); formatParams.Reset();
Worksheet
setSelectedRange(str range) -> None / getSelectedRange() -> str
Specifies the current cell range selection.
After selecting a new range, the corresponding active worksheet will be scrolled to ensure that range (or at least its top-left cell) is visible.Setting a selection automatically de-select any currently selected objects.
Example:
wsheet.setSelectedRange("c20");
wsheet.UpdateWindow();
gscalc.Sleep(2000);
wsheet.setSelectedRange("c20:d22");
gscalc.Sleep(2000);
wsheet.setSelectedRange("2:2");
gscalc.Sleep(2000);
wsheet.setSelectedRange("H:I");
setTopLeftCell(str range) -> None / getTopLeftCell() -> str
Specifies the top-left cell of the worksheet window.
Example:
wsheet.setTopLeftCell("c20");
Scroll(str type, bool scrollSelection) -> None
Scrolls the worksheet view. If scrollSelection is False,
calling this method corresponds to dragging the scroll boxes of the view scrollbars (and to pressing scrolling
keys with the "Scroll Lock" key on.
If scrollSelection is False (and the "Scroll Lock" key off),
calling this method corresponds to pressing the cursor keys.
Unlike other methods, Scroll enforces screen updates during the execution
of the script so UpdateWindow() doesn't have to be used.
The type argument can be of the following text strings:
- line-down
- line-up
- line-right
- line-left
- page-down
- page-up
- page-right
- page-left
- top
- bottom
- home
- end
Example:
for i in range(0, 50) :
wsheet.Scroll("line-down", True);
gscalc.Sleep(200);
Address(int column, bool relativeColumn, int row, bool relativeRow) -> str
Creates and returns a string representing the specified relative or absolute cell address,
depending on the logical relativeColumn and relativeRow
arguments.
To obtain only the column or row name/number, specify 0 as the 2nd argument.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); cell = wsheet.Address(3, True, 20, False); # returns "C$20" cell = wsheet.Address(3, False, 0, False); # returns "$C"
RC(str range) -> int left, int top, int right, int bottom
Returns four integers representing the top-left and bottom-right coordinates of the specified cell or range. The numbers are returned in the following order: the left column, the top row, the right column and the bottom row.
Example:
cell = wsheet.RC("b10") # returns 2, 10, 2, 10
cell = wsheet.RC("b10:c20"); # returns 2, 10, 3, 20
Column(str cell) -> int
Returns the column number of the specified cell address.
Example:
column = wsheet.Column("C20"); # returns 3
Row(str cell) -> int
Example:
column = wsheet.Column("C20"); # returns 20
GetFirstColumn() -> int
Returns the number of the first non empty column.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); column = wsheet.GetFirstColumn();
GetFirstRow() -> int
Returns the number of the first non empty row.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); row = wsheet.GetFirstRow();
GetLastColumn() -> int
Returns the number of the last non empty column.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); column = wsheet.GetLastColumn();
GetLastRow() -> int
Returns the number of the last non empty row.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); row = wsheet.GetLastRow();
GetMaxColumn() -> int
Returns the highest usable column number.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); column = wsheet.GetMaxColumn();
GetMaxRow() -> int
Returns the highest usable row number.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); row = wsheet.GetMaxRow();
CreateFormattingParams() -> FormatParams
Creates and returns an object containing cell formatting parameters. The FormatParams object is then used to retrieve existing cell formats and to set new ones.
Example:
wsheet.setSelectedRange("b1:b20");
GetCellFormat(FormatParams params) -> None
Retrieves a cell format for the selected cell or range. The corresponding column or row format is ignored and must be obtained using the GetColumnFormat() and GetRowFormat() methods.
Example:
wsheet.GetCellFormat(formatParams);
GetColumnFormat(FormatParams params) -> None
Retrieves a column format relative to the selected cell or range.
Example:
wsheet.GetColumnFormat("b10:b20", formatParams);
GetRowFormat(FormatParams params) -> None
Retrieves a row format relative to the selected cell or range.
Example:
wsheet.GetRowFormat(formatParams);
SetCellFormat(FormatParams params) -> bool
Formats the selected cell or range of cells using formatting attributes set in the FormatParams object.
If the range doesn't include any complete columns or rows, the formatting
will be applied to subsequent individual cells.
If the selected range specifies a column selection (e.g. c1:c12582912, h1:12582912, c:c, c:h), the formatting
will be applied to whole columns.
If the selected range specifies a row selection (e.g. a10:fan10, 1:1, 4:6), the formatting
will be applied to whole rows.
Example:
SetCellCustomStyle(str name) -> bool
Formats the selected cell or a range of cells using a user-defined custom cell style/format. Cell styles can be added, edited and deleted via the "Format > Custom Cell Styles" dialog box or via the "Format > Cell Format" dialog box.
Example:
wsheet.SetCellCustomStyle("cell style 1.");
DeleteCells(bool dialogBox, str contentType) -> bool
Deletes selected cell(s). The showDialogBox argument
is a logical value that specifies whether the Delete dialog box should be displayed.
The contentType argument is a text string specifying the type
of the deleted data. It can be any combination of the
- numbers
- labels
- formulas
- data
- formatting
- lists
- comments
Example:
wsheet.setSelectedRange("c10:c20");
wsheet.DeleteCells(False, "data");
wsheet.setSelectedRange("d10");
wsheet.DeleteCells(False, "formatting");
wsheet.setSelectedRange("b4");
wsheet.DeleteCells(True, "formatting, lists, comments");
CopyCells(int copyType) -> bool
Copies selected cell(s).The contentType argument is a numeric 0-7 value specifying the type of the copy action:
- 1 - simple copy action
- 2 - copy and transpose
- 3 - copy and reverse rows
- 4 - copy and reverse columns
- 5 - simple copy with formulas replaced by their values
- 6 - copy values and transpose
- 7 - copy values and reverse rows
- 8 - copy values and reverse columns
Example:
wsheet.CopyCells(0);
wsheet.PasteCells(True);
wsheet.setSelectedRange("b5");
wbook.WaitForUpdate(); # to allow the background updating to complete before further actions
PasteCells(bool textAndFormatting) -> bool
Pastes previously copied cell(s) or the textual data from the Clipboard.
The textAndFormatting argument
is a logical value specifying whether the copied cells should be pasted along
with their formatting.
If the current selection is a single cell, the copied and pasted data block will
be the same. If the current selection spans multiple rows and/or columns, the pasted
data will be duplicated, filling the selected range if it's bigger than the source range.
Executing a large number of the PasteCells actions will be faster if the updateMode property is set to manual and the application/workbook window is minimized.
Example:
wsheet.setSelectedRange("b5:b10");
GetColumnWidth() -> str
Returns width of the current column (a column related to the top-left cell of the selection) in pixels. The width is calculated for the view scale = 100%. If the column width is automatic, the "auto" string is returned.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); width = wsheet.GetColumnWidth();
SetColumnWidth(str width) -> bool
Sets the width for the columns included in the currently selected range. The width argument is a text string that can represent either a width in pixels related to the view scale = 100% or the "auto" text string. The latter causes adjusting the widths to the contained data.
Example:
wsheet.setSelectedRange("b5:e5");
wsheet.SetColumnWidth("auto");
wsheet.setSelectedRange("f5");
wsheet.SetColumnWidth("30");
GetRowHeight() -> str
Returns the height of the current row (a row related to the top-left cell of the selection) in pixels. The height is calculated for the view scale = 100%. If the row height is automatic, the "auto" string is returned.
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); height = wsheet.GetRowHeight();
SetRowHeight(str height) -> bool
Sets the height for the rows included in the currently selected range. The height argument is a text string that can represent either a width in pixels related to the view scale = 100% or the "auto" text string. The latter turns on automatic heights (that is, heights adjusted to the contained data).
Example:
wsheet.SetRowHeight("auto");
wsheet.SetRowHeight("30");
InsertColumns(int type) -> bool
Inserts new columns based on the currently selected range. The argument is a numeric value that specifies the following:
- 1 - inserts a blank column(s) before the selection
- 2 - inserts a column(s) before the selection with the same formatting
- 3 - inserts a column(s) before the selection with the same formatting and size
- 4 - inserts a column(s) before the selection with the same formatting, size and unmodified formulas
- 5 - inserts a blank column(s) after the selection
- 6 - inserts a column(s) after the selection with the same formatting
- 7 - inserts a column(s) after the selection with the same formatting and size
- 8 - inserts a column(s) after the selection with the same formatting, size and unmodified formulas
Example:
wsheet.InsertColumns(1);
wsheet.InsertColumns(3);
DeleteColumns() -> bool
Deletes columns based on the currently selected range.
Example:
wsheet.DeleteColumns();
InsertRows(int type) -> bool
Inserts new rows based on the currently selected range. The argument is a numeric value that specifies the following:
- 1 - inserts a blank row(s) before the selection
- 2 - inserts a row(s) before the selection with the same formatting
- 3 - inserts a row(s) before the selection with the same formatting and size
- 4 - inserts a row(s) before the selection with the same formatting, size and unmodified formulas
- 5 - inserts a blank row(s) after the selection
- 6 - inserts a row(s) after the selection with the same formatting
- 7 - inserts a row(s) after the selection with the same formatting and size
- 8 - inserts a row(s) after the selection with the same formatting, size and unmodified formulas
Example:
wsheet.InsertRows(1);
wsheet.setSelectedRange("b11");
wsheet.InsertRows(3);
DeleteRows() -> bool
Deletes rows based on the currently selected range.
Example:
wsheet.DeleteRows(1);
wsheet.DeleteRows(3);
InsertSeries() -> bool
Insert a new data series based on the currently selected range. For the detailed description of this function, please see the "Entering data > Inserting series" help topic.
Example:
wsheet.setSelectedRange("b5:b100");
wsheet.InsertSeries();
IsText(str cell-or-range) -> bool / IsTextRC(int row, int column) -> bool
Returns True if the specified cell contains a text or label.
If cell is a cell range, the method returns True
if that range contains at least one text string and zero or more empty cells.
Otherwise the False value is returned.
Example:
check1 = wsheet.IsText("b5:b100");
check2 = wsheet.IsText("b101");
IsNumber(str cell-or-range) -> bool / IsNumberRC(int row, int column) -> bool
Returns True if the specified cell contains a number.
if that range contains at least one number and zero or more empty cells.
Example:
check1 = wsheet.IsNumber("b5:b100");
check2 = wsheet.IsNumber("b101");
IsFormula(str cell-or-range) -> bool / IsFormulaRC(int row, int column) -> bool
Returns True if the specified cell contains a formula.
if that range contains at least one formula and zero or more empty cells.
Example:
check1 = wsheet.IsFormula("b5:b100");
check2 = wsheet.IsFormula("b101");
IsFormulaNumericRC(int row, int column) -> bool
IsFormulaTextualRC(int row, int column) -> bool
IsError(str cell-or-range) -> int / IsErrorRC(int row, int column) -> int
Returns the first found error code for the specified cell or range or 0 if the cell or range doesn't contain any cells/formulas returning errors. The possible error codes are as follows:
- 1 - #DIV/0!
- 2 - #NAME?
- 3 - #NULL!
- 4 - #N/A!
- 5 - #NUM!
- 6 - #REF!
- 7 - #VALUE!
- 8 - #MEMORY!
- 9 - #FILL!
- 12 - #SYNTAX!
Example:
check1 = wsheet.IsError("b5:b100");
check2 = wsheet.IsError("b101");
InsertData(str cell-or-range, str data, bool parse) -> bool
Inserts data into the specified cell or range.
The data argument can be any text string containing up to 1024 characters.
The parse argument is a logical value that specifies whether the submitted data
should be parsed automatically and inserted as a number, date, a text string or a formula. If it's set
to False, the entered data will be always treated as text - same as pressing
Enter vs Enter+Shift when entering cell contents.
This function fully simulates manual data entering.
When entering large data sets, it's typically much faster to use the Copy/Paste and InsertSeries methods
and their variants.
Using InsertData() method will be also much faster if the updateMode
as shown in the 2nd example below.
Example 1.:
wsheet.InsertData("b5", "11.5", True);
wsheet.InsertData("b6", "1.7", True);
wsheet.InsertData("b7:b10", "-0.1", True);
wsheet.InsertData("b11", "=sum(b5:b10)", True);
Example 2.:
gscalc.MinimizeAppWindow();
updateMode = wbook.getUpdateMode();
wbook.setUpdateMode("manual");
for i in range(1, 200000) :
ref = "b" + i;
wsheet.InsertData(ref, "some text data", False);
wbook.setUpdateMode(updateMode);
gscalc.RestoreAppWindow();
InsertNumber(str cell, float value) -> bool / InsertNumberRC(int row, int colum, float value) -> bool
InsertText(str cell, str text) -> bool / InsertTextRC(int row, int colum, str text) -> bool
InsertFormula(str cell, str formula) -> bool / InsertFormulaRC(int row, int colum, str formula) -> bool
InsertComments(str cell, str comments) -> bool / InsertCommentsRC(int row, int colum, str comments) -> bool
Adds comments to specified cell. The comments argument can be any text string containing up to 1024 characters.
Example:
wsheet.InsertComments("b5", "comments in b5");
wsheet.InsertComments("b6", "comments in b6");
InsertMatrix(str topLeftCell, matrix) -> bool
GetData(str cell, bool formatted) -> str
Returns data from the specified cell. The returned data can represent:
- a numeric or textual cell value
- a numeric or textual result of a formula
- a text string representing an error code
- an undefined value for an empty cell
Example:
sum = wsheet.GetData("b5:b10"); # sum = 12.8
GetNumber(str cell) -> float / GetNumberRC(int row, int column) -> float
GetText(str cell) -> str / GetTextRC(int row, int column) -> str
GetFormula(str cell) -> str / GetFormulaRC(int row, int column) -> str
Returns formula from the specified cell that contains some formula.
If the specified cell doesn't contain a formula, an empty string is returned.
Example:
formula = wsheet.GetFormula("b11"); # formula = "sum(b5:b10)"
GetComments(str cell) -> str / GetCommentsRC(int row, int column) -> str
Returns comments for the specified cell. If the cell doesn't have comments, an empty string is returned.
Example:
comments = wsheet.GetComments("b5"); # comments = "comments in b5"
GetMatrix64F(str range) -> matrix (float64)
GetMatrix32F(str range) -> matrix (float32)
GetMatrix64I(str range) -> matrix (int64)
GetMatrix64U(str range) -> matrix (uint64)
GetMatrix32I(str range) -> matrix (int32)
GetMatrix32U(str range) -> matrix (uint32)
GetMatrix8I(str range) -> matrix (int8)
GetMatrix8U(str range) -> matrix (uint8)
GetSparseMatrix(str range, int type) -> array (uint32), array (uint32), array (float64)
InsertSparseMatrix(str topLeftCell, rows (array), columns (array), values (array)) -> bool
TerminateUpdateThreads() -> None
UpdateWindow()
UpdateWindow enforces GS-Calc to perform any pending screen updates of the workbook window before the script terminates and passes the control back to it.
Example:
wsheet.setTopLeftCell("cv100");
gscalc.Sleep(3000);
wsheet.setSelectedRange("ab10");
SaveSelectionAsImage(str filePath) -> bool
Saves the currently selected chart or image (if an object is selected)
or the current cell range (if no object is selected) as an image to the specified file.
The image format is determined by the file extension: *.png, *.jpg, *.gif, *.bmp, *.tiff.
If the file argument is an empty string,
the standard Save File dialog box is displayed.
Example:
wsheet.SaveSelectionAsImage("d:\\image1.png");
Print(bool dialogBox, str range, str pageList) -> bool
Prints the active worksheet. The "rangeType" string can be one of the following:
- all - printing all pages and all data
- default - same as "all"
- pages - printing a page range specified by the "printedPages" property
- selection - printing a currently selected range of cells
Example:
wbook = gscalc.ActiveWorkbook(); wsheet = wbook.GetActiveWorksheet(); wsheet.Print(False, "pages", "2,3,6-7");
Workbook
ActiveWorksheet() -> Sheet
Returns the active worksheet object. All methods called on this object always refers to the currently selected worksheet.
Example:
wbook.SelectTreeItem("sheet1");
wsheet.InsertData("b5", "data entered in sheet1!b5", True);
wbook.SelectTreeItem("sheet2");
wsheet.InsertData("b5", "data entered in sheet2!b5", True);
SetActiveWorksheet(str path) -> bool
SetActiveFolder(str path) -> bool
GetActiveFolderPath() -> str
GetActiveWorksheetPath() -> str
GetWorksheetCount() -> int
Returns the number of worksheets in the workbook.
Example:
wbook = gscalc.ActiveWorkbook(); counter = wbook.GetWorksheetCount();
GetFolderCount() -> int
Returns the number of folders in the workbook.
Example:
wbook = gscalc.ActiveWorkbook(); counter = wbook.GetFolderCount();
IsFolderEmpty(str folder) -> int
Returns True if the specified folder doesn't contain any tree items (worksheets or folders) and False otherwise.
Example:
empty = wbook.IsFolderEmpty("folder1");
GetFirstTreeItem(str folder) -> str
Returns the first tree item (worksheets or folders) of the specified folder. If the folder argument is an empty string, the first item of the entire worksheet tree is returned. The returned value has a form of the full tree tree path.
Example:
item1 = wbook.GetFirstTreeItem("");
if wbook.IsFolder(item1) :
item2 = wbook.GetFirstTreeItem(item1);
GetPrevTreeItem(str path) -> str
Returns the previous sibling tree item (a worksheet or a folder) for the specified worksheet tree item.
Example:
item2 = wbook.GetNextTreeItem(item1);
item3 = wbook.GetPrevTreeItem(item2);
# item1 == item3 if there are at least two sibling items in the main folder of the worksheet tree.
item1 = wbook.GetFirstTreeItem("folder1\\subfolder2");
# item1 == item3 if there are at least two sibling items in the "subfolder2" folder.
GetNextTreeItem(str path) -> str
Returns the next sibling tree item (a worksheet or a folder) for the specified worksheet tree item.
Example:
GetParentFolder(str path) -> str
Returns the full path of the folder that contains the specified worksheet tree item (either a folder or a worksheet). If treeItem is top/root element, an empty string is returned.
Example:
item = wbook.GetFirstTreeItem("folder1\\subfolder2");
parent = wbook.GetParentFolder(item);
# parent == "folder1\subfolder2"
IsWorksheet(str path) -> int
Returns the logical True value if the specified worksheet tree item is a worksheet. Otherwise False is returned.
Example:
check1 = wbook.IsWorksheet("folder1\\sheet10");
check2 = wbook.IsWorksheet("abc");
IsFolder(str path) -> int
Returns the logical True value if the specified worksheet tree item is a folder. Otherwise False is returned.
Example:
check1 = wbook.IsFolder("folder1\\sheet10");
check2 = wbook.IsFolder("abc");
ExpandFolder(str folder) -> bool
Expand the specified folder in the worksheet tree window.
Example:
wbook.ExpandFolder("folder1");
CollapseFolder(str folder) -> bool
Collapse the specified folder in the worksheet tree window.
Example:
wbook.CollapseFolder("folder1");
SelectTreeItem(str path) -> bool
Changes selection in the worksheet tree window. The new selected tree item
is specified by the full path argument. If it points
to a worksheet, the current active worksheet is changed automatically as well.
If path is an empty string, the top/root folder is selected.
Example:
InsertFolder(str name) -> bool
Inserts a new folder into the current worksheet tree folder. The name argument must not include tree path elements.
Example:
wbook.SelectTreeItem("folder2");
wbook.InsertFolder("nested-folder3");
InsertWorksheet(str name) -> bool
Inserts a new worksheet into the current worksheet tree folder. The name argument must not include tree path elements.
Example:
wbook.SelectTreeItem("");
wbook.InsertFolder("sheet1");
DeleteTreeItem() -> bool
Deletes the currently selected worksheet tree item (which can be a single worksheet or a folder containing other folders and worksheets).
Example:
wbook.SelectTreeItem("folder4");
wbook.DeleteTreeItem();
wbook.SelectTreeItem("folder5\\sheet1");
MoveTreeItem(str sourcePath, str targetPath) -> bool
Moves a worksheet tree item performing the equivalent of the drag-and-drop operation.
If the targetPath specifies a worksheet, the moved item(s)
are inserted before it in the same folder.
If the targetPath specifies a folder, the moved item(s)
are inserted as the last item(s) in that folder. An empty targetPath
specifies the top/root folder.
Example:
wbook.MoveTreeItem("folder1\\sheet11", "folder2");
wbook.MoveTreeItem("folder1\\sheet10", "");
CopyTreeItem(str sourcePath, str targetPath) -> bool
RenameTreeItem(str path) -> bool
Changes the name of the currently selected worksheet tree item (except the top/root item).
Example:
wbook.RenameTreeItem("folder_4");
wbook.SelectTreeItem("pivot tables\\customers")
wbook.RenameTreeItem("new customers");
GetNamedRangeCount()
Returns the number of defined named ranges.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.GetNamedRangeCount();
GetNamedRange(index, propertyName)
Returns the name and cell range of the named expression specified by index. The type of the returned string is determined by the propertyName argument and can be "name" or "range".
Example:
wbook = gscalc.ActiveWorkbook(); name = wbook.GetNamedRange(2, "name"); cell = wbook.GetNamedRange(2, "range");
SetNamedRange(index, rangeName, range)
Set the existing named range specified by index.
Example:
wbook = gscalc.ActiveWorkbook(); if wbook.GetNamedRangeCount() > 3 : wbook.SetNamedRange(1, "start", "a10"); wbook.SetNamedRange(2, "name", sheet1!c4); wbook.SetNamedRange(3, "sales", "\"d:\\[sample.gsc]Folder1\"!$A$1:$E$5");
AddNamedRange(rangeName, range)
Adds a new named range specified by index.
Example:
wbook.AddNamedRange("start", "a10");
wbook.AddNamedRange("name", sheet1!c4);
wbook.AddNamedRange("sales", "\"d:\\[sample.gsc]Folder1\"!$A$1:$E$5");
RemoveNamedRange(index)
Removes an existing named range specified by index.
Example:
wbook = gscalc.ActiveWorkbook(); while wbook.GetNamedRangeCount() >= 1 : wbook.RemoveNamedRange(1);
RemoveAllNamedRanges()
Removes all defined named ranges.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.RemoveAllNamedRanges();
Save() -> bool
Saves the workbook using the current file format and file path. If this is a new workbook, the Save As dialog box is displayed.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.Save();
SaveAs(str filePath) -> bool
Saves the current workbook to a new file. If path is an empty string, Save As dialog box is displayed.
Example:
wbook.SaveAs("d:\\wbook1.gsc");
SaveAsPDFFile(str filePath, bool saveAllWorksheets) -> bool
Saves the current workbook to the specified PDF file. If the logical
saveAllWorksheets value is True, all worksheets are saved
and the tree structure is preserved in that PDF file.
If saveAllWorksheets is False, only the current/active worksheet
is saved.
When saving to PDFs the current worksheets print/page settings determine the layout of
PDF pages.
The method doesn't change the file path information or the modification state
of the original workbook.
If path is an empty string, the Save As
Example:
wbook.SaveAsPDFFile("d:\\copy_of_wbook1.pdf");
SaveAsExcelFile(str filePath) -> bool
Saves the current workbook as a new Excel XML file.
Example:
wbook.SaveAsExcelFile("d:\\wbook1.xml");
SaveAsTextFile(str filePath, bool dialogBox, TextParams params) -> bool
Saves the current workbook as a new text file using the provided TextParams object.
If showDialogBox is True,
the Save Text File dialog box is displayed.
Example:
textParams.setSeparator("\t"); # tab-separated values
wbook.SaveAsTextFile("d:\\wbook1.txt", False, textParams);
wbook.SaveAsTextFile("d:\\wbook2.txt", True, textParams);
SaveAsXBaseFile(str filePath, bool dialogBox, XBaseParams params) -> bool
Saves the current workbook as a new xBase file using the provided XBaseParams object.
the Save xBase File dialog box is displayed and it contains
a suggested set of fields based on the data the worksheet contains.
Example:
xBaseParams.setEncoding("windows");
wbook.SaveAsXBaseFile("d:\\wbook1.dbf", False, xBaseParams);
wbook.SaveAsXBaseFile("d:\\wbook2.dbf", True, xBaseParams);
Reload() -> bool
Reloads the workbook. All changes are discarded.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.Reload();
Close() -> bool
Closes the workbook. If the modified property is True, users are prompted to save it.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.Close(); counter = wbook.GetWorksheetCount();
GetFileInfo(str filePath, int type) -> str
Returns information about the specified file without opening it. The type argument determines what is returned:
- 1 - file size, in bytes
- 2 - last modification date
Example:
# file size in bytes
size = gscalc.GetFileInfo("c:\\file01.gsc", 1);
# last modification date in the format YYYY-MM-DD (YYYY-MM-DDTHH:MM:SS)
modificationData = gscalc.GetFileInfo("c:\\file01.gsc", 2);
ReleaseFile() -> str
Detaches and closes the currently open workbook file. The workbook and its window remain open and you keep on editing it
allowing other programs to access that file at the same time.
If you try to save it without calling the AttachFile() function first, the Save As dialog box will be displayed.
Example:
wbook = gscalc.ActiveWorkbook(); path = wbook.ReleaseFile();
AttachFile(str filePath) -> int
Attaches previously detached file and open it. Returns 1 if a given file was modified after ReleaseFile(), 0 if not and -1 if the file can't be opened and attached
Example:
wbook.AttachFile("c:\\text_file01.csv");
MergeRows(MergeParams params) -> bool
Merges/adds rows from other GS-Calc *.gsc files and tables to the current worksheet. The mergeParams
parameters are created using the CreateMergeParams() method.
For all parameters see the MergeParams description.
Example:
merge = gscalc.CreateMergeParams();
# merge records from all *.gsc files with names starting with "gsc_file"
merge.setPath("c:\\gsc_file*.gsc");
merge.setTable("");
wbook.MergeRows(merge);
MergeRowsFromODSFile(MergeParams params) -> bool
Merges/adds rows from other *.ods files and tables to the current worksheet. The mergeParams parameters
Example:
# merge records from all *.ods files with names starting with "ods_file"
merge.setPath("c:\\ods_file*.ods");
merge.setTable("");
wbook.MergeRowsFromODSFile(merge);
MergeRowsFromTextFile(MergeParams params, TextParams params) -> bool
Merges/adds rows from other *.txt files to the current worksheet. The mergeParams parameters
are created using the CreateMergeParams() method and textParams - with the CreateTextParams() method.
For all parameters see the MergeParams and TextParams descriptions.
Example:
textParams.setSeparator(",");
# merge records from all *.csv files with names starting with "csv_file"
mergeParams.setPath("c:\\csv_file*.csv");
mergeParams.setTable("");
wbook.MergeRowsFromTextFile(mergeParams, textParams);
MergeRowsFromExcelFile(MergeParams params) -> bool
Merges/adds rows from other *.xlsx files and tables to the current worksheet. The mergeParams parameters
Example:
# merge records from all *.xlsx files with names starting with "xlsx_file"
merge.setPath("c:\\xlsx_file*.xlsx");
merge.setTable("");
wbook.MergeRowsFromExcelFile(merge);
MergeRowsFromXBaseFile(MergeParams params, XBaseParams params) -> bool
Merges/adds rows from other dBaseIV *.dbf files and tables to the current worksheet. The mergeParams parameters
are created using the CreateMergeParams() method and xBaseParams - CreateXBaseParams.
Example:
# merge records from all *.dbf files with names starting with "dbf_file"
merge.setPath("c:\\dbf_file*.dbf");
merge.setTable("");
xbaseParams = gscalc.CreateXBaseParams();
xbaseParams.setEncoding("windows");
wbook.MergeRowsFromXBaseFile(merge, xbaseParams);
MergeRowsFromMySQLFile(MergeParams params) -> bool
MergeRowsFromSQLiteFile(MergeParams params) -> bool
MergeTable(str filePath, str tablePath) -> bool
Merges/adds tables from other GS-Calc *.gsc files to the current workbook and currently selected folder.
"Path" specifies a file(s) with tables to merge. The path can contain a file name with wildcard (*, ?) characters,
enabling you to merge tables from multiple files from a given folder or all files from that folder.
If no table name is specified (table="" / NULL), then the default/current table from a given file is added.
Example:
# merge tables from all *.gsc files with names starting with "gsc_file"
wbook.MergeTable("c:\\gsc_file*.gsc", "customers");
MergeTableFromODSFile(str filePath, str table) -> bool
Merges/adds tables from other *.ods files to the current workbook and currently selected folder.
Example:
# merge tables from all *.ods files with names starting with "ods_file"
wbook.MergeTableFromODSFile("c:\\ods_file*.ods", "customers");
MergeTableFromTextFile(str filePath, str table, TextParams params) -> bool
Merges/adds tables from other text files to the current workbook and currently selected folder.
Example:
# merge tables from all *.csv files with names starting with "csv_file"
wbook.MergeTableFromTextFile("c:\\csv_file*.csv", "", textParams);
MergeTableFromExcelFile(str filePath, str table) -> bool
Merges/adds tables from other *.xlsx files to the current workbook and currently selected folder.
Example:
# merge default tables from all *.xlsx files with names starting with "xlsx_file"
wbook.MergeTableFromExcelFile("c:\\xlsx_file*.xlsx", "");
MergeTableFromXBaseFile(str filePath, str table, XBaseParams params) -> bool
Merges/adds tables from other dBaseIV *.dbf files to the current workbook and currently selected folder.
Example:
# merge tables from all *.dbf files with names starting with "dbf_file"
wbook.MergeTableFromXBaseFile("c:\\dbf_file*.dbf", "", xBaseParams);
MergeTableFromMySQLFile(str filePath, str table) -> bool
MergeTableFromSQLiteFile(str filePath, str table) -> bool
SetFilePassword(bool enable, str cryptMethod, str oldPassword, str newPassword) -> bool
Sets, modifies or removes password protection for the workbook.
If the logical enable argument is True,
the password protection is added, if it's False, the protection
is removed.
The method argument can currently be only the "blowfish"
encryption method name.
If the workbook is already password protected, the oldPassword
argument must contain the existing password.
If enable is True, the newPassword
argument must contain a new password consisting of at least 6 characters.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.SetFilePassword(True, "blowfish", "Df8ER1", "97uYwp"); wbook = gscalc.NewWorkbook(); wbook.SetPassword(True, "blowfish", "", "97uYwp");
SetCellPassword(bool enable, str oldPassword, str newPassword) -> bool
Sets, modifies or removes password protection for individual cells.
Once this password is set, the Format > Protect command
can be used to set the cell protection.
If enable is True, the newPassword argument must contain a new password consisting of at least 6 characters.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.SetCellPassword(True, "Df8ER1", "97uYwp");
SetTreePassword(bool enable, str oldPassword, str newPassword) -> bool
Sets, modifies or removes password protection for the worksheet tree structure and view splitters.
is removed.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.SetTreePassword(True, "Df8ER1", "97uYwp");
UpdateAllWorksheets() -> bool
Updates all formulas in all worksheets in this workbook. (Same as the Update All - F9 command.)
Example:
wbook = gscalc.ActiveWorkbook(); wbook.UpdateAllWorksheets(); wbook.WaitForUpdate(); # to allow the background updating to complete before further actions
UpdateActiveWorksheet() -> bool
Updates all formulas in the active worksheet. (Same as the Update Worksheet Shift+F9 command.)
GS-Calc enables you to load/save quickly extremely large files and use multicore calculations for any formulas
using dynamic references because it doesn't pre-build calculation trees. However, the disadvantage of this is
that if you use the UpdateAllWorksheets() method, GS-Calc will be unconditionally
updating all formulas in all worksheets, no matter whether the current data change requires it.
Setting the updateMode to manual and using sequences
of the UpdateActiveWorksheet() and/or UpdateAllWorksheetRegion()
methods relevant to your worksheets design, you can greatly increase the update speed.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.UpdateActiveWorksheet(); wbook.WaitForUpdate(); # to allow the background updating to complete before further actions
UpdateActiveWorksheetRegion(str range) -> bool
Updates all formulas in the specified range in the active worksheet.
Example:
wbook.UpdateActiveWorksheetRegion("a5:b1000000");
wbook.UpdateActiveWorksheetRegion("g5:m1000000");
WaitForUpdate() -> None
If the background updating mode in turned on and there is an updating process running, the method
waits till that process completes.
If the background updating mode is turned off, the method returns immediately.
Performing any editing action before the update completes restarts the updating process.
Some actions (like saving) can't be carried out before the pending update completes.
For efficiency reasons it's recommended that you set the updateMode property to "manual" before performing a massive data editing/entering actions.
Example:
MaximizeWindow() -> None
Maximizes the workbook window.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.MaximizeWindow();
RestoreWindow() -> None
Restores the previous size of the workbook window after it's maximized.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.RestoreWindow();
setModified(bool value) -> bool / getModified() -> bool
A logical value specifying whether the contents of the workbook was modified. It's managed automatically by the program. Typically, modifying it explicitly might be necessary only to avoid notifications about closing an unsaved workbook.
Example:
wbook = gscalc.ActiveWorkbook(); wbook.setModified(False); wbook.Close()
setUpdateMode(str mode) -> bool / getUpdateMode() -> str
Specifies whether formulas are updated automatically or manually. The method accepts the following strings as its argument:
- default - application defaults
- manual - manual updating (to update, use GUI commands or "update" script methods)
- automatic - automatic updating (formulas are updated whenever any workbook data changes)
Example:
setUpdateThreads(str threads) -> bool / getUpdateThreads() -> str
Specifies the number of threads/CPUs used when updating workbook formulas:
- any number from 1 to 16
Example:
wbook.setUpdateThreads(4);
wbook.setUpdateThreads("default");
Application
CreateXBaseParams()
Creates and returns an object containing xBase (dBase, Clipper, FoxPro) file format details. The XBaseParams object is then used to retrieve header/fields information of an existing opened database file or to create header/fields structure for a new database file.
Example:
CreateTextParams()
Creates and returns an object containing text file format details. The TextParams object is then used to open existing text files and to create new ones.
Example:
CreateMergeParams
path
table
If it's null/empty string, the default/active table is used.fieldNames
Default: 0matchFieldNames
Default: 0enableUndo
Default: 0
Example:
ActiveWorkbook(str path, str password) -> Workbook
Returns the Workbook object corresponding to the workbook that contains the executed script or (if the script is not a part of the workbook contents) to the current workbook.
Example:
wbook2 = gscalc.NewWorkbook();
wbook3 = gscalc.OpenWorkbook("d:\\sales2013\\june.gsc", "");
NewWorkbook() -> Workbook
Creates a new workbook and returns the corresponding Workbook object.
Example:
OpenWorkbook(str path) -> Workbook
Opens an existing workbook in the *.gsc or *.odf file format
If path is an empty string, the Open File
Example:
wbook4 = gscalc.OpenWorkbook("d:\\sales2013\\june.ods", "FE2OkP");
OpenTextFile(str path, bool dialogBox, TextParams params) -> Workbook
Opens an existing text file and returns the corresponding Workbook object.
the Open Text File dialog box is displayed.
Example:
wbook1 = gscalc.OpenTextFile("d:\\wbook1.txt", False, textParams);
wbook2 = gscalc.OpenTextFile("d:\\wbook2.txt", True, textParams);
OpenExcelFile(str path) -> Workbook
Opens an existing workbook in the Excel *.xlsx file format
Example:
wbook = gscalc.OpenExcelFile("d:\\sales2020\\june.xlsx");
OpenXBaseFile(str path, bool dialogBox, XBaseParams params) -> Workbook
Opens an existing xBase file and returns the corresponding Workbook object.
the Open xBase File dialog box is displayed.
Example:
wbook1 = gscalc.OpenXBaseFile("d:\\wbook1.dbf", False, xBaseParams);
xBaseParams.setFormat("clipper");
wbook2 = gscalc.OpenXBaseFile("d:\\wbook2.dbf", True, xBaseParams);
OpenMySQLFile(str path) -> Workbook
OpenSQLiteFile(str path) -> Workbook
LoadProfile(str path) -> bool
Loads profile information from the specified XML file. If path is an empty string, the Open File dialog box is displayed.
Example:
gscalc.LoadProfile("d:\\profiles\\prof1.xml");
SaveProfile(str path) -> bool
Save profile information to the specified XML file. If path is an empty string, the Save dialog box is displayed.
Example:
gscalc.SaveProfile("d:\\profiles\\prof1.xml");
GetWorkbookCount() -> int
Returns the number of open workbooks.
Example:
counter = gscalc.GetWorkbookCount();
CloseAllWorkbooks() -> bool
Closes all open workbooks.
Example:
wbook = gscalc.ThisWorkbook(); gscalc.CloseAllWorkbooks(); counter = wbook.GetWorksheetCount();
TileWorkbooks() -> None
Tiles open workbook windows vertically or horizontally.
Example:
gscalc.TileWorkbooks(True); gscalc.TileWorkbooks(False);
MaximizeAppWindow() -> None
Maximizes the application window.
Example:
gscalc.MaximizeAppWindow();
MinimizeAppWindow() -> None
Minimizes the application window.
Example:
RestoreAppWindow() -> None
Restores the previous size and position of the application window after it's minimized or maximized.
Example:
GetFilePath(bool saveAs, str title, str folder, str name, str ext) -> bool, str
Displays the "File" dialog box and returns selected file path.
- saveAs
1/0, True/False - if it's 1, the "Save As" type dialog box will be displayed. Otherwise, the "Open" file dialog box, which requires a given file to exist. - title
The dialog box title such as "Save As" or "Open File". - folder
The initial folder that the dialog box shows. You can also use a full file path for this. For example, "d:\\docs\\files", "e:\\reports\\doc_file\\feb\\file01.xlsx" - name
The initial file name displayed in the "File name" field. - ext
The initial file extension filter that determines which the initial "Files of type" combo box selection.
You can simply put here the full file path or just the extension:
".gsc",
".ods",
".txt", ".csv", ".tsv",".tab", ".zip",
".xlsx",
".xml",
".dbf",
Example:
openFilePath = gscalc.GetFilePath(False, "Open XLSX File", "d:\\", "d:\\newfile.xlsx", ".xlsx");
GetFolder(str title, str folder) -> bool, str
Displays the (file) "Folder" dialog box and returns selected folder path.
- title
The dialog box title such as "Select Folder". - folder
Example:
folderPath = gscalc.GetFolder("Select Folder", "d:\\");
MessageBox(str message, str buttons, int activeButton, str icon) -> bool, str
Displays a message box using the following arguments:
- message
The message text to display. - buttons
A text string specifying which buttons will appear in the message box. This must be one of the following strings:
- ok
- ok-cancel
- retry-cancel
- yes-no
- yes-no-cancel
- abort-retry-ignore
- button
An index 1-3 of the default message box button. - icon
A text string specifying which icon appear in the message box. This must be one of the following strings:
- exclamation
- warning
- information
- question
- error
- abort
- cancel
- continue
- ignore
- no
- ok
- retry
- tryagain
- yes
Example:
accepted, ret = gscalc.MessageBox("Open this file: calc1.gsc", "yes-no", 1, "question")
if ret == "yes" :
wbook = gscalc.OpenWorkbook("d:\\sales2013\\calc1.gsc", "");
InputBox(str title, bool password, str initialValue) -> bool, str
Displays a simple, one-line input box using the following arguments:
- title
The input field title. - password
A logical value specifying whether the edit control should use the password style, masking the entered characters. - initValue
The initial string displayed in the edit control.
Example:
accepted, name = gscalc.InputBox("Enter your name", False, "");
Sleep(time)
Suspend the execution of the script for the specified time in milliseconds.
Example:
gscalc.Sleep(5000);
SetStatusBarText
Specifies the text displayed in the 1st pane of status bar.
Example:
gscalc.SetStatusBarText("Executing script...");
