Charts in Cells
You can display mini‑charts directly inside cells using two methods:
  1. SPARKLINE() Function
    The SPARKLINE() function creates a mini‑chart using two parameters:
    • the data point values
    • an array of chart setup parameters
    This is a standard Google Sheets function; its full description is available online. GS-Calc additionally supports the interval and axisstyle parameters.
    Sparkline example
  2. Format → In‑Cell Chart
    The Format → In‑Cell Chart command allows you to create any number of cell mini‑charts with a single click. All parameters and display options are configured automatically.
    By default, this in‑cell format is applied to cells at the end of a data series in a row. However, charts can also be displayed at the beginning of a row series, or above/below a column series — the chart position is determined by the cell’s text alignment.
    Format → In‑Cell Chart menu:
    In‑Cell Chart menu
    Sample in‑cell charts:
    In‑Cell Chart examples
