GS-Base Help > Opening and Saving Excel Workbooks
To Save a Database (or Just the Current Filtered Table) as an Excel Workbook
Use the File > Save Database Copy As or the File > Save Record Set As command and choose the Excel *.xlsx format or the Excel 97-2003 *.xls file format from the File of type list.
In the Save Excel File dialog box, specify the following options:
Note: After saving a document in a different format, you may need to use the File > Reload command to refresh the view.
To Open an Excel Workbook
Use the File > Open command (or alternatively any of the external table merging commands) and choose the Excel *.xlsx format or the Excel 97-2003 *.xls format from the File of type list.
In the Open Excel File dialog box, specify the following options:
Note: if subsequent worksheets in the same merged sequence have more columns, empty columns are added automatically to the preceding worksheets.
Related Topics
GS-Base zip database file format
