GS-Base Help > Using Table, Form and Binary Views
By default, records in a newly created database are displayed in tables. Tables can be split into separate views to enable synchronized scrolling of different regions of a given table.
Form views can be activated using the View > Form command. They can be displayed side by side with the corresponding table view, or the table view can be hidden.
The form layout is mostly automatic. You can specify various other options using the View > Form Options command.
Multi-column forms enable you, e.g., to view/inspect tens of fields at once.
Multi-column form view
Binary views are used to display Long Text, Images/Files and Code fields. They are opened automatically if you add such contents. You can still explicitly show/hide them using the View menu commands, or simply by pressing Enter or double-clicking the corresponding table/form field.
