GS-Base Help > Comparing records in two tables
To compare records in two tables and find differences regardless of their order, use the Tools > Compare Tables command. The dialog box allows you to specify the tables to compare and choose whether to save the differences as an editable report or simply display the number of varying records:
Compare Tables
Compare Tables
