| JScript and VBscipt scripting |
Sample JScripts scripts
Creating and saving a new database
Adding and removing records, updating calculated fields
Adding, removing and renaming tables and subfolders
Importing tables from GS-Base databases, text and Excel files
Merging records from all text and Excel files in a folder
Formatting record fields
Setting column/field widths and row heights
Browsing the folders/tables tree
Searching and sorting
Predefined searching
File password protection
Enabling sharing databases and text, Excel and other files
Opening and saving text files
Error handling
List of all properties and functions
File/database opening
Saving databases
Saving databases as new files
Saving recordsets
Importing tables databases, text and Excel files
Performing JOIN operations for tables in the same database file
Merging/adding records from other files
Switching the active table
Record counters
Searching
Adding, modifying and removing fields
Browsing the database folder and tables tree structure
Editing records
Inserting series
Changing column widths and row heights
Setting record flags
Setting database passwords for GS-Base *.gsb/*.zip files
File information and access
Updating all calculation formulas
Input/output UI functions
Window functions
Obtaining the last error details
To make scripting accessible, you need to perform one-time GS-Base scripting registration using the "Settings > Register GS-Base Scripting" command in the admin mode. (Right-click the GS-Base shortcut or file and choose "Run As Administrator", register, close GS-Base). This registers GS-Base in Windows registry as a program that can be scripted not only in GS-Base, but also using external programming tools. (The "Unregister(...)" command removes the added entries.)
You can create your scripts either as global scripts saved in the program settings and available to all databases or you can
create scripts stored in a given GS-Base database and available only after you open that database.
To create these scripts use the "File > Application Scripts" and "File > Database Scripts" commands.
The "(...) Scripts" dialog box enables you to organize your scripts in subfolders, test them to locate errors, copy/import/export them etc.
Notes:
If a database is already loaded, an executed script, either global or local, automatically refers to that database and using the Open(...) functions with the same database path has no effect.
//// a new database with a the "table1" table GSBase.NewDatabase("table1"); // insert another "table1" in the root ("") folder at the bottom; // as "table1" already exists, the uniqueName will contain a unique // name table1(1)...table1(n) that GS-Base will create and use instead; var uniqueName = GSBase.InsertDatabaseItem("", 1, "table1"); var field = GSBase.CreateFieldParams(); // add one Text field to the currently selected table; // // adding and importing a table make it 'selected' automatically; // deleting tables may result in a new selection; // SetActiveTable() and GetActiveTable() set and retrieve the selection // field.name = "field1"; // T - text field // N - numeric field // M - long text / Memo // O - objects (images, files etc.) // C - code field (long text with specific syntax highlighting) field.type = 'T'; GSBase.AppendField(field); //add one Number field with range validation // field.Reset(); field.name = "field2"; field.type = 'N'; field.formula = "=(field2 > 1) * (field2 < 10)"; // 1 - calculation formula/calculated field // 2 - validation formula // 3 - conversion formula // 4 - default value // 5 - incremented maximum field.formulaType = 2; GSBase.AppendField(field); //add one calculated Number field // field.Reset(); field.name = "field3"; field.type = 'N'; field.formula = "=field2 * 10"; field.formulaType = 1; GSBase.AppendField(field); //insert one more Text field at the beginning of the record field.Reset(); field.name = "field4"; field.type = 'T'; GSBase.InsertField(1, field); //add one Code field that uses the "cpp" syntax highlighting field.Reset(); field.name = "field5"; field.type = 'C'; //subtypes same as in the "Field Setup": "cpp", "assembler", "php"... field.subtype = "cpp"; GSBase.AppendField(field); //choose to use the standard zip (zip32) file format for the new database; the default value for new files is "true" ("use zip64"); for existing database files their the default value is the one that was used previously; //GSBase.zip64 = true; GSBase.zip64 = false; //save a new database (with one table and no records so far); GSBase.SaveDatabaseAs("e:\\test_dbase.gsb"); GSBase.Close();
var password = "fhE4!lko"
GSBase.OpenDatabase("e:\\test_dbase.gsb", password);
//all editing actions always refer to the currently selected table;
//once a table is selected (and the database is saved), it remains selected till you change this;
if (GSBase.GetActiveTable() != "table1")
GSBase.SetActiveTable("table1");
//as the table contains the calculated "field3", for performance reasons turn off
//recalculation of each row which would otherwise occur after each of the 10,000 modifications below;
//to restore the default automatic updating use "automatic" or re-open the database;
GSBase.updateMode = "manual";
//NOTE: InsertText() and InsertNumber() do exactly what plain entering data does
//which means they set up Undo information and refreshes the screen which makes them slow. If you need
//to fill millions of fields instantly, use the Insert(...)Series() functions family instead.
//NOTE: for best performance, when inserting a large series of data, always fill the table fields
//in the "top to bottom" (and "left to right") order. The "bottom to top" order may
//be considerably slower.
//insert the following date string in the 1st record field in 100 records;
var today = "2021-01-15";
for (i = 1; i <= 100; ++i)
GSBase.InsertText(i, 1, today);
//insert some numbers in the 3rd record field in the first 100 records
GSBase.InsertNumber(i, 3, 2.0 + i%8);
//update all calculated fields in this table using 4 processor cores
GSBase.UpdateTable(4);
//get the sum of the 4th field for the entire current record set
var counter = GSBase.GetRecordSetCount();
var sum = 0;
for (i = 1; i <= counter; ++i)
sum = sum + GSBase.GetNumber(i, 4);
//clear the 3rd field in records 11 to 21
GSBase.ClearRange(11, 3, 21, 3);
//update all "field3" calculated fields as the "manual" update mode was set earlier
//remove record 1
GSBase.RemoveRecords(1, 1);
//remove records 2 to 3
GSBase.RemoveRecords(2, 3);
//remove record 11
GSBase.RemoveRecords(11, 11);
// save using the current file format and file format options
GSBase.Save();
GSBase.Close();
Adding, removing and renaming tables and folders
GSBase.OpenDatabase("e:\\test_dbase.gsb", "");
//notes:
//insert a new folder "folder1\" in the root folder at the bottom;
//if "folder1" already exists at that level, the uniqueName will contain a unique
//name folder1(1)...folder1(n) that GS-Base will create and use instead;
var uniqueName = GSBase.InsertDatabaseItem("", 1, "folder1\\");
//insert folder2 at the top
GSBase.InsertDatabaseItem("", 0, "folder2\\");
GSBase.InsertDatabaseItem("\\folder1\\", 1, "folder1\\");
GSBase.InsertDatabaseItem("folder1", 1, "folder1\\");
//rename the "text_abc(2)" table in the "\folder2" folder to "test_abc_b";
GSBase.RenameDatabaseItem("\\folder2\\test_abc(2)", "test_abc_b");
//delete the entire "folder2" folder
GSBase.DeleteDatabaseItem("\\folder2\\");
//delete the "\folder1\test_abc_b" table
GSBase.DeleteDatabaseItem("\\folder1\\test_abc_b");
GSBase.Save();
GSBase.Close();
Importing tables from GS-Base databases, text files and Excel workbooks
//import the "product" table from the sample.zip database and insert it in the root folder GSBase.ImportTable("e:\\sample.zip", "products", "", "\\"); //import to the "folder1" subfolder GSBase.ImportTable("c:\\sample2.zip", "products2", "pass4563word!", "folder1"); //import the first table from file_a.xlsx and insert it in the root folder //first row in file_a.xlsx contains field names GSBase.ImportExcelTable("e:\\excel_data\\file_a.xlsx", "", 1, ""); //import the first table from file_c.xlsx and insert it in the root folder //first row in file_a.xlsx doesn't contain field names GSBase.ImportExcelTable("e:\\excel_data\\file_c.xlsx", "", 0, ""); //import the first table from file_a.xlsx and insert it in the root folder //first row in file_a.xlsx doesn't contain field names GSBase.ImportExcelTable("e:\\excel_data\\file_i.xlsx", "", 0, ""); //create text file parameters var textParams = GSBase.CreateTextParams(); //use "|" as the field separator ("," is the default one) textParams.separator = "|"; //import a new table from the "text_abc.txt" text file and place it in the "folder2" folder GSBase.ImportTextTable("c:\\test_abc.txt", "", textParams, "\\folder2\\"); //import it again (the name of the imported table will be modified to "text_abc(1)") GSBase.ImportTextTable("c:\\test_abc.txt", "", textParams, "\\folder2\\"); //import it again (the name of the imported table will be modified to "text_abc(2)") GSBase.ImportTextTable("c:\\test_abc.txt", "some_name", textParams, "\\folder2"); GSBase.Save(); GSBase.Close();
var mergeParams = GSBase.CreateMergeParams();
// merge record e.g. from report2000.txt, report2001.txt, ..., report2023.txt
mergeParams.path = "e:\\gsb19_test\\report20??.txt";
// don't perform field names matching, add fields "as is"
// note: field types must match, text fields can't be copied to numeric fields
mergeParams.matchFieldNames = false;
textParams.encoding = "windows";
GSBase.MergeRecordsFromTextFile(mergeParams, textParams);
// if there are calculated fields, update all records using 4 processor cores
// you can also only perform more complex merging using the "mergeType" property:
// mergeParams.mergeType=0 - merge records unconditionally (default value)
// mergeParams.mergeType=1 - merge records only with new values of the mergeParams.slaveIndex field from merged files
// mergeParams.mergeType=2 - update records in the main table where the specified fields in the main/master table and in the merge tables are the same, mergeParams.masterIndex = mergeParams.slaveIndex
// mergeParams.mergeType=3 - delete records from the main table where the specified fields in the main/master table and in the merge tables are the same, mergeParams.masterIndex = mergeParams.slaveIndex
// For Excel and other file format use:
// MergeRecords(mergeParams)
// MergeRecordsFromTextFile(mergeParams, textParams)
// MergeRecordsFromExcelFile(mergeParams, namesInFirstRow)
// MergeRecordsFromXBaseFile(mergeParams, xBaseParams)
// MergeRecordsFromMySQLFile(mergeParams)
Record merging functions
GSBase.Save();
GSBase.Close();
GSBase.OpenDatabase("e:\\test_dbase.gsb", 0);
//select the "table1" table in the root folder
GSBase.SetActiveTable("\\table1");
//create formatting settings
var format = GSBase.CreateFormatParams();
//set the currency format: variable/automatic number of decimals and the exponent value
//parameters:
//1. decimals: 0 - 14 | "auto"
//2. currency position: "$1.1" | "$ 1.1" | "1.1$" | "1.1 $"
//3. currency symbol: "$", "GBP" etc.
//4. true - use curly braces for negative values
//5. true - use red color for negative values
format.SetCurrencyFormat("2", "$1.1", "gbp", true, true);
// other style examples:
//set the scientific style: 5 decimal digits and the fixed "07" exponent
//----- format.SetScientificFormat("5", "07");
//set the scientific style: variable/automatic number of decimals and the exponent value
//----- format.SetScientificFormat("auto", "auto");
//set the accounting style
//parameters:
//2. currency symbol: "$", "GBP" etc.
//----- format.SetAccountingFormat("2", "gbp");
//set the fractional format
//parameters:
//1. if the 2nd parameter is "false", (1) is a denominator value 2, 3, ..., n;
// if the 2nd parameter is "true", (1) is a fixed number of denominator digits 1...14
//2. ...
//----- format.SetFractionFormat(2, true);
//set the general number format
//parameters:
//2. leading zeroes: 0 - 14
//3. true - use curly braces for negative values
//4. true - use red color for negative values
//5. true - use the thousand separator
//----- format.SetGeneralNumberFormat("auto", 5, false, false, true);
GSBase.SetFieldFormat(3, format);
//set the date format
//parameters:
//1. a date pattern: same as in the "Format > Style" window
//2. 1 - always switch to the current Windows system day/month order ("m/d..." | "d/m...")
format.SetDateFormat("m/d/yyyy", 1);
GSBase.SetFieldFormat(1, format);
//clear the previously set information
format.Reset();
format.fontSize = 14;
format.boldFont = true;
GSBase.Save();
GSBase.Close();
//get the 1st column/field width in screen pixels
var width = GSBase.GetColumnWidth(1);
//set a new width
width += 50;
GSBase.SetColumnWidth(1, width);
//fit the 3rd column/field width to the data in that column/field
GSBase.FitColumnWidth(3, 3);
//get the 9th row/record height in screen pixels: typically it should be 25px
var height = GSBase.GetRowHeight(9);
//set a new height
height += 20;
GSBase.SetRowHeight(9, height);
//check the "auto-height" state of the 9th row
var autoHeight = GSBase.GetAutoRowHeight(9);
//restore on the "auto-height" state for the 9th row
GSBase.SetAutoRowHeight(9, 9, true);
//should be true now
//it should be 25px again
GSBase.Save();
GSBase.Close();
//1st method
//get the total number of tables and folders in the main/root folder (including nested folders)
var counter = GSBase.GetDatabaseItemCount();
//iterate through all table/folders
var path = GSBase.GetDatabaseItem(i);
if (path.length && path.charAt(path.length - 1) == '\\')
//folder
var ret = GSBase.MessageBox("folder - " + path, "ok", 1, "information");
else
//table
var ret = GSBase.MessageBox("table - " + path, "ok", 1, "information");
var ret = GSBase.MessageBox(path, "ok", 1, "information");
//2nd method
//get the first "child" element in the specified folder, e.g. the main/"root" folder
//var path = GSBase.GetFirstDatabaseItem("\\folder2(1)\\");
var path = GSBase.GetFirstDatabaseItem("\\");
//iterate through direct "child" elements of the specified folder (not expanding nested folders)
while (path.length)
if (path.charAt(path.length - 1) == '\\')
//folder
else
//table
path = GSBase.GetNextDatabaseItem(path);
GSBase.Close();
GSBase.SetActiveTable("\\products");
//find the "ProductName" and "UnitPrice" fields;
//filter "ProductName" and sort "UnitPrice"
//reset the previous sorting indices - resetting should be used before calling "put_sortIndex()"
GSBase.ResetSorting();
var iname = 0;
var iprice = 0;
for (i = 1; i <= GSBase.GetFieldCount() && (!iname || !iprice); ++i)
GSBase.GetField(i, field);
if (!iname && field.name == "ProductName")
//set the "\Ai" RegEx filter for "ProductName" (=search for names starting with "I");
//searching is performed automatically if a call to the "SetField" changes the "filter" value;
//note: in this version the filter type is always "RegEx"
field.filter = "\\Ai";
GSBase.SetField(iname = i, field);
if (!iprice && field.name == "UnitPrice")
//set the 1 as the sorting index for "UnitPrice";
//sorting is performed automatically after a call to "SetField" if the "sorting" index is modified;
//to create a compound sorting index, use subsequent numbers (2, 3...) for further fields;
//note: using an index not in that strictly incremented manner causes an error;
field.sortIndex = 1;
// 'A' - ascending order, 'D' - descending order
field.sortOrder = 'A';
GSBase.SetField(iprice = i, field);
GSBase.Save();
GSBase.Close();
//find duplicates in the 5th field
GSBase.FindDuplicates(5, 5, 1, false, false);
//check the results
var counter1 = GSBase.GetRecordTotalCount();
var counter2 = GSBase.GetRecordSetCount();
//check the results
//find records with the flag "1"
GSBase.FindFlagged(1);
//find the records not included in the current record set
GSBase.FindComplement();
//clear all filters and display all records
GSBase.FindAll();
GSBase.Close();
//set a password GSBase.OpenDatabase("e:\\test_dbase.gsb", ""); GSBase.SetFilePassword(true, "blowfish", "", "rocc4545"); GSBase.Save(); GSBase.Close(); //open a password-protected database GSBase.OpenDatabase("e:\\test_dbase.gsb", "rocc4545"); //... //GSBase.Save(); GSBase.Close(); //remove password protection GSBase.OpenDatabase("e:\\test_dbase.gsb", "rocc4545"); GSBase.SetFilePassword(false, "blowfish", "rocc4545", ""); GSBase.Save(); GSBase.Close();
var fpath = GSBase.ReleaseFile()
GSBase.MessageBox("File closed: " + fpath, "ok", 1, "information");
//You can keep on viewing/working with this file in GS-Base as usual (as it's in RAM).
//It can be edited in other programs.
//At any moment you can execute the following script, which will check for updates:
if (GSBase.AttachFile(fpath) == 1)
// AttachFile returned 1, so the file was modified
// after ReleaseFile(), you can ask whether reload
// it now or later
GSBase.Reload();
else
// no changes detected, so leave the file accessible
// for any other programs.
GSBase.ReleaseFile();
// 1. Exporting the current record set to a text file // ----------------------------------------------- GSBase.OpenDatabase("e:\\test_dbase.gsb", ""); //select the "table1" table in the root folder GSBase.SetActiveTable("\\products"); //create text file parameters var textParams = GSBase.CreateTextParams(); //use ";" as the field separator; the default value is "," textParams.separator = ";"; //use of separators can be turned off; the default value is true //textParams.useSeparator = false; //use "'" as the quoting symbol; the default value is """ textParams.quotingSymbol = "'"; //use of quoting symbols can be turned off; the default value is true //textParams.useQuoting = false; //save field names in the first row; the default value is true textParams.fieldNames = true; //change the text encoding: "utf8" | "windows" | "dos"; the default value is "utf8" textParams.encoding = "utf8"; //export the current table to a text file; //"dbase" remains the originally opened database and can edited further as usual GSBase.SaveRecordSetAsText("e:\\test_b.txt", textParams); // 2. Opening and saving a text file // --------------------------------- //re-use the above "txt" settings and add new ones //if a column contains textual representations of numbers, try converting them to a number field textParams.parseNumbers = true; //if a column contains textual representations of dates in various formats, convert these strings //to the generic "DT" W3 text representation of dates in GS-Base (please see the "data types" help topic for details). textParams.parseDates = true; GSBase.OpenTextFile("e:\\test_b.txt", textParams); var fcounter = GSBase.GetFieldCount(); var field = GSBase.CreateFieldParams(); GSBase.GetField(1, field); // // ...perform any editing, field changes etc. // //save the edited text file GSBase.Save(); GSBase.Close(); // 3. Opening a text file and saving it as a database // -------------------------------------------------- //re-use the above "txt" textParams.parseNumbers = false; GSBase.OpenTextFile("e:\\test_b.txt", txt); //SaveDatabaseAs changes "textFile" to a database with the path given below; the text file is closed GSBase.SaveDatabaseAs("e:\\sample_b.gsb"); // // ...perform any editing, field actions etc. with "e:\\sample_b.gsb" // GSBase.Close();
// if a COM funcion returns an error other than E_OUTOFMEMORY,
// additional error information can obtained via the "lastError" property;
var code = GSBase.lastError;
// 21 // Out of memory while creating/editing worksheet data
// 22 // A database must contain at least one table
// 37 // Invalid password.
// 53 // Not allowed field type change - e.g. conversion form "Files/Images" to "Number"
// 61 // Can't open the specified file
// 62 // Can't open or create the specified file
// 63 // Error while closing the specified file
// 64 // Error while repositioning a file pointer
// 65 // Error while reading from a file
// 66 // Error while writing to a file
// 67 // Error while deleting a file
// 68 // Error while checking the file size/info
// 69 // Error while allocating a file read/write buffer
// 70 // Can't open the specified file. File in use.
// 71 // Error while decrypting a file.
// 72 // Error while encrypting a file.
// 73 // Error while reading binary fields."
// 79 // Can't find the manifest file or its content is incorrect
// 80 // The file format requires a newer GS-Base version.
// 119 // Too many zip streams in a standard zip (zip32) file
// 120 // Inconsistent zip stream state
// 121 // Corrupted zip stream data
// 122 // Out of memory while processing a zip stream
// 123 // Unexpected end of zip stream
// 125 // Unknown zlib error
// 131 // Some data in the file can't be converted to numeric field values.
GSBase.Close();
File/database opening functions
| NewDatabase(tableName) | |
| OpenDatabase(path, password) | If the database is not encrypted, password should be ""/null. |
| OpenTextFile(path, showDialogBox, textParams) | showDialogBox = 1 to show the standard "Open Text File" dialog box. textParams - an object created with GSBase.CreateTextParams(). |
| OpenExcelFile(path, showDialogBox, mergeType, options) | showDialogBox = 1 to show the standard "Open Excel File" dialog box. mergeType - represents the 0...3 "merge" radio buttons from the "Open Excel File" dialog box. options - a combination of 1, 2, 4 (1 - field names in the 1st worksheet, 2 - field names in every worksheet, 4 - restore GS-Base table/folder tree paths). |
| OpenHtmlFile(path, fnames) | fnames = 1 if there are field names in the 1st row of the html table (note: the table must have the "id" attribute set to "gsbase"). |
| OpenXBaseFile(path, showDialogBox, xBaseParams) | showDialogBox = 1 to show the standard "Open xBase File" dialog box. xBaseParams - an object created with GSBase.CreateXBaseParams(). |
| OpenMySQLFile(path) | |
| Close() | Closing is also automatic when subsequent "open" methods are used.|
| Reload() | Reloads the opened file using originally used file format settings
params = GSBase.CreateTextParams() - settings corresponding to the "Open Text File" dialog box options
| params.useSeparator | 0, 1 |
| params.separator | any character |
| params.fixedFieldWidths | for example, "10,20,30,15" |
| params.encoding | "utf8", "utf16", "windows" |
| params.useQuoting | 0, 1 |
| params.quotingSymbol | any character |
| params.fieldNames | 0, 1 (field names in the first row) |
| params.parseNumbers | 0, 1 |
| params.parseDates | 0, 1 |
| params.saveLongTextAsZip | 0, 1 |
| params.saveObjectsAsZip | 0, 1 |
| params.autoFitColumns | 0, 1 |
params = GSBase.CreateXBaseParams() - settings corresponding to the "Open xBase File" dialog box options
| params.format | "dbaseIII", "dbaseIV", "foxpro", "clipper" |
| params.encoding | "windows", "dos" |
| params.GetFieldCount() | |
| params.SetField(index, name, type, length, decimals) | type: "C", "N", "F", "L", "D", "M" |
| params.AddField(name, type, length, decimals) | |
| params.params.InsertField(index, name, type, length, decimals) | |
| params.GetFieldName(index) | index: 1...number of fields |
| params.GetFieldType(index) | |
| params.GetFieldLength(index) | |
| params.GetFieldDecimals(index) | 0, 1 |
| params.DeleteField(index) |
| SaveRecordSetAs(path, password) | |
| SaveRecordSetAsText(path, textParams) | If the file is not to be encrypted, password should be ""/null. |
| SaveRecordSetAsExcel(path, split, fnames, saveZip) | |
| SaveRecordSetAsXBase(path, format, xBaseParams) | |
| SaveRecordSetAsMySQL(path) | |
| SaveRecordSetAsPDF(path) | |
| zip64 | 0, 1 - specify whether ZIP64 or the older standard Windows ZIP32 should be used for *.gsb and *.xlsx files. |
Note: Unlike "SaveDatabaseAs" methods, recordset saving methods do not change the current database path or state.
| Save() | Saves the current file using the current file format and its current file format settings |
| SaveTextFile(textParams) | Enables you to modify settings when saving a previously opened text files.|
| SaveExcelFile(split, fnames, saveZip) | |
| SaveXBaseFile(xBaseParams) | |
| SaveMySLQFile() |
| SaveDatabaseAs(path) | |
| SaveDatabaseAsExcel(path, int split, fnames, saveZip) | |
| SaveDatabaseAsMySQL(path) | |
Note: The above methods change the current database path, saving a new copy of a given database.
| ImportTable(filePath, tablePath, password, folder) |
If tablePath="", the first found table from "filePath" is imported The target "folder" must exist or the parameter must be empty. If folder="", the imported table is inserted in the main/root folder |
| ImportTextTable(textFilePath, tableName, textParams, folder) |
If tableName="", the inserted table name will be the same as the text file name The target "folder" must exist or the parameter must be empty. If folder="", the imported table is inserted in the main/root folder |
| ImportExcelTable(excelFilePath, tableName, namesInFirstRow, folder) |
| MergeTable(masterField, tablePath, slaveField, allowDuplicates) |
masterField - 1-based index of the field in the current table tablePath - full path of the joined table slaveField - 1-based index of the related field in the joined table allowDuplicates - 0, 1: specifies whether duplicated values in the joined table should result in adding multiple joined records in the result table |
| MergeRecords(mergeParams) | Merge records from another *.gsb database mergeParams - an object created with GSBase.CreateMergeParams(). | |
| MergeRecordsFromTextFile(mergeParams, textParams) | textParams - an object created with GSBase.CreateTextParams() | |
| MergeRecordsFromExcelFile(mergeParams, namesInFirstRow) | ||
| MergeRecordsFromXBaseFile(mergeParams, xBaseParams) | xBaseParams - an object created with GSBase.CreateXBaseParams()||
| MergeRecordsFromMySQLFile(mergeParams) |
params = GSBase.CreateMergeParams() - settings corresponding to the record merging options
| params.path | full file path; the file name contain wildcard characters to enable mass merge of files from a given folder, for example, "e:\\folder\\*.csv", "f:\\folder\\*20??.gsb", "c:\\report*.xlsx" |
| params.table | full table path for *.gsb, *.xlsx and *.sql files; if it's empty the first table in the specified file is used. |
| params.masterField | 1-based index of the field in the current table; used only if the mergeType <> 0 |
| params.slaveField | 1-based index of the related field in the merged table; used only if the mergeType <> 0 |
| params.mergeType |
0 - add all records, 1 - add records where the "slaveField" values don't exist in the main table 2 - update records in the main table where the "slaveField" values exist in the main table 3 - delete records from the main table where the "slaveField" values exist in the main table |
| params.matchFieldNames | 0, 1; used only if the mergeType=0 and causes adding records unconditionally, without matching field names in both tables |
| params.ignoreEmpty | 0, 1; used only if the mergeType=2 and causes not using empty fields |
| params.enableUndo | 0, 1; specifies whether the UI Undo command should be enabled for merging; it's 0 by default as the undo information can multiple the memory usage for these actions |
| SetActiveTable(path) | path - full table path | |
| GetActiveTable() |
| GetRecordTotalCount() | |
| GetRecordSetCount() | |
| GetFieldCount() |
| FindDuplicates(fieldFrom, fieldTo, searchAll, type, sortResults) |
fieldFrom and fieldTo are 1-based field indices. Field in this range are treated as the search key. searchAll: 0, 1 - if it's 1, GS-Base will search for duplicates in the current filtered record set; otherwise the entire table is searched. type=0 - show all duplicates, type=1 - show first records from each group of duplicates, type=2 - show the last record from each group of duplicates, type=3 - all duplicates except the first from each group, type=4 - all duplicates except the last one from each group sortResults: 0,1 - sort the obtained records using the above key. | |
| FindUnique(fieldFrom, fieldTo, searchAll, type, sortResults, useCounters, counterIndex) |
fieldFrom and fieldTo are 1-based field indices. Field in this range are treated as the search key. searchAll: 0, 1 - if it's 1, GS-Base will search for duplicates in the current filtered record set; otherwise the entire table is searched. type=0 - if there are duplicates, show first records from each group of duplicates, type=1 - if there are duplicates, show the last record from each group of duplicates, useCounters: 0, 1 - use 1 to specify a field where the number of occurences will be saved, counterIndex: 1-based index of a numeric field, where the number of occurences will be saved, sortResults: 0,1 - sort the obtained records using the above key. | |
| FindQuartile(field, searchAll, statAll, type) |
The "type" parameter can be a mix of the following values: 1: 1st, 2: 2nd, 4: 3rd, 8: 4th, 16: below mean, 32: above mean statAll: 0, 1 - if it's 1, the statistics will be calculated for the entire table, otherwise for the current recordset. | |
| FindRandom(n) | n randomly selected records from the current recordset | |
| FindFlagged(flag) | flg: a flag index from 1 to the number of created flags | |
| FindComplement() | Shows all record not included in the current recordset | |
| FindAll() | Shows all records. |
Note: regular field filter are set using the SetField() function.
| AppendField(fieldParams) | fieldParams - an object created with GSBase.CreateFieldParams() |
| InsertField(field, fieldParams) | |
| AppendField(fieldParams) | |
| RemoveField(field) | |
| GetField(field, fieldParams) | |
| SetField(field, fieldParams) | SetField() triggers filtering and/or sorting if the respective data was set in the fieldParams |
| ConvertField(field, type) | |
| ResetSorting() | Clears any currently defined single or multiple sort key |
params = GSBase.CreateFieldParams() - settings corresponding to the record field definition
| params.name | |
| params.type |
"T" - textual "N" - numeric "M" - LongText "C" - Code "O" - Images/Files |
| params.subType | used for the "C" field type: "cpp", "cpp/rc", "cpp/idl(odl)", "c#", "assembler", "java", "jscript", "vbscript/vb.net", "html", "xml", "flash", "php", "python", "perl", "powershell", "sql". Choosing the subtype causes applying the correct language syntax and keyword coloring. |
| params.hlink | 0, 1 |
| params.sortIndex | 1 for single key sorting or 1-based index for multi-key sorting |
| params.sortOrder | "A" or "D" |
| params.formula | e.g. "=some_numeric_field_name + 10" |
| params.formulaType |
1 - calculation formula/calculated field 2 - validation formula 3 - conversion formula 4 - default value 5 - incremented maximum |
| params.filter | sets the current filter expression; if it changes, the SetField() method will trigger searching |
| params.filterType |
1 - regex 2 - plain text pattern 3 - equal 4 - not equal 5 - greater than 6 - less than 7 - between 8 - and 9 - or 10 - is empty 11 - is similar 12 - flag index |
| params.matchCase | 0, 1 |
| params.matchWords | 0, 1; match whole words for full text plain searching |
| params.Reset() | Clear all set options and flags |
| GetDatabaseItemCount() | The total number of tables and folders in a database file. | |
| GetDatabaseItem(index) | Return full tables and folders paths | |
| GetFirstDatabaseItem(folder) | ||
| GetNextDatabaseItem(prevName) | ||
| RenameDatabaseItem(path, name) | ||
| DeleteDatabaseItem(path) |
NOTE: InsertText() and InsertNumber() do exactly what plain entering data does which means they set up Undo information and refreshes the screen which makes them slow. If you need to fill millions of fields instantly, use the Insert(...)Series() functions family instead.
| RemoveRecords(recordFrom, recordTo) | |
| InsertRecords(recordFrom, recordTo) | |
| InsertText(record, field, text) | |
| GetText(record, field) | |
| InsertNumber(record, field, number) | |
| GetNumber(record, field) | |
| Clear(record, field) | |
| ClearRange(record1, field1, record2, field2) |
Note: all record numbers are relative to the current, filtered and sorted (or not) record set. They are equal to physical cardinal record numbers in a table only if they are not active searches or sort keys.
| InsertSeries(field, recordFrom, recordTo, copy) |
copy=0 - numeric or date/time sequence copy=1 - copying the top item within the selected range See: Inserting series | |
| InsertRecurrenceSeries(field, recordFrom, recordTo, formula) | See: Inserting series | |
| InsertCustomSeries(field, recordFrom, recordTo, series) | See: Inserting series | |
| InsertRandomSeries(field, recordFrom, recordTo, distribution, param1, param2) | See: Inserting series |
| GetColumnWidth(field) | |
| SetColumnWidth(field, width) | |
| FitColumnWidth(fieldFrom, fieldTo) | |
| GetRowHeight(record) | |
| SetRowHeight(record, height) | |
| GetAutoRowHeight(record) | |
| SetAutoRowHeight(recordFrom, recordTo, val) | val: 0, 1 |
| CreateFormatParams() | |
| GetFieldFormat(field, formatParams) | field - 1-based field index, formatParams - an object created with GSBase.CreateFormatParams() |
| SetFieldFormat(field, formatParams) |
params = GSBase.CreateFormatParams() - format/style settings
| params.SetGeneralNumberFormat(decimals, zeroes, brackets, inRed, separators, scaling) |
1. decimals: 0 - 14 | "auto" 2. leading zeroes: 0 - 14 3. true - use curly braces for negative values 4. true - use red color for negative values 5. true - use the thousand separator For example: params.SetGeneralNumberFormat("auto", 5, false, false, true); |
| params.SetCurrencyFormat(decimals, position, symbol, brackets, inRed, scaling) |
1. decimals: 0 - 14 | "auto" 2. currency position: "$1.1" | "$ 1.1" | "1.1$" | "1.1 $" 3. currency symbol: "$", "GBP" etc. 4. true - use curly braces for negative values 5. true - use red color for negative values For example: params.SetCurrencyFormat("2", "$1.1", "gbp", true, true); |
| params.SetAccountingFormat(decimals, symbol, scaling) |
1. decimals: 0 - 14 | "auto" 2. currency symbol: "$", "GBP" etc. For example: params.SetAccountingFormat("2", "gbp"); |
| params.SetDateFormat(pattern, systemOrder) |
1. a date pattern: same as in the "Format > Style" window 2. 1 - always switch to the current Windows system day/month order ("m/d..." | "d/m...") For example: params.SetDateFormat("m/d/yyyy", 1) |
| params.SetTimeFormat(pattern) | |
| params.SetDateTimeFormat(datePattern, timePattern, systemOrder, timeFirst)(index, name, type, length, decimals) | |
| params.SetPercentFormat(decimals, scaling) |
decimals - the number of decimal places; this can be "auto" or any number from 0 to 14. Default value: "auto" scaling - the display factor as a power of 1000; this can be any number from 0 to 5. Default value: 0 |
| params.SetFractionFormat(denominator, digits) |
1. if the 2nd parameter is "false", (1) is a denominator value 2, 3, ..., n if the 2nd parameter is "true", (1) is a fixed number of denominator digits 1...14 2. ... For example: params.SetFractionFormat(2, true); |
| params.SetScientificFormat(decimals, exponent) |
For example: 5 decimal digits and the fixed "07" exponent params.SetScientificFormat("5", "07") variable/automatic number of decimals and the exponent value params.SetScientificFormat("auto", "auto"); |
| params.DeleteField(index) | |
| params.fontName | |
| params.fontSize | 0, 1 |
| params.boldFont | |
| params.italicFont | |
| params.underlineFont | |
| params.strikeoutFont | |
| params.fontColor | |
| params.horzAlignment | |
| params.vertAlignment | |
| params.wrapText | |
| params.shrinkText | |
| params.Reset |
| GetRecordFlag(record) | |
| SetRecordFlag(recordFrom, recordTo, flag) | flag index - 1 to the number of defined flags |
| SetFilePassword(enable, cryptMethod, oldPassword, newPassword) |
enable: 0, 1 cryptMethod: "blowfish" oldPassword: empty if settings a new password newPassword: empty if removing password protection |
Note: The industry-level encryption include the entire database contents and all fields (textual, numeric, LongText, Code, Images/Objects). Information included in JScript and VBscript scripts stored either as GS-Base global settings or scripts added to files using the "File > Database Scripts" command is not encrypted.
| GetFileInfo(path, type) | type=1 - returns the file size, type=2 - return the last modification date in the format YYYY-MM-DD |
| ReleaseFile() | Closes, detaches the current database file and return its file path. This enables updating records by another processes/users. Using "Save()" before attaching the file back causes displaying the "File Save As" dialog box. |
| AttachFile(path) | Attach a given file to the current database loaded in RAM and returns 0 if the file has been modified after the most recent use of the Release() function. |
| UpdateTable(procCores) | Update calculation formulas in all records. By default, record editing actions cause updating the modified records only. |
| updateMode | Can be: "default", "automatic", "manual". Changing this value from "automatic" to "manual" can be helpful if there are many "block" editing actions (field editing, conversion, clearing ranges) and only one final UpdateTable() will be sufficient instead of multiple time-consuming automatic updates. |
| MessageBox(message, buttons, button, icon) |
The "button" parameter must be one of the following strings:
The "icon" parameter must be one of the following strings:
| InputBox(title, isPassword, initValue) | |
| Sleep(unsigned long time) |
| MaximizeAppWindow() | |
| MinimizeAppWindow() | |
| RestoreAppWindow() |
| lastError |
Related Topics
