A cell style is a set of formatting properties (font, data style, borders, background) used to display a single cell.
Style palettes are collections of all cell styles currently in use across all worksheets in a workbook (excluding charts and inserted objects). Style palettes update dynamically as formatting changes are applied.
2. Editing Style Palette Entries
GS-Calc allows editing of all properties of existing style palette entries, including the default cell style.
Changing the default style affects all cells that do not have user‑defined formatting. For example, modifying the default background color will change the background of all unformatted cells.
3. Managing Style Palettes
Style palette management tools are available in:
- Format → Style Palette (resizable window)
- Format → Cell Format dialog (when Format → Advanced Cell Format Dialog Options → Show Style Lists is enabled)
