1. imageIf(if_condition, path_true, path_false, type)
Displays an image in a cell (overflowing cell boundaries if necessary).
if_condition:
If non‑zero, path_true is displayed; otherwise path_false.
path_true / path_false:
Image file paths or names.
- If type = 1: paths refer to external disk files (e.g., e:\image_file1.png).
- If type = 0: names refer to images inserted into the workbook using Insert > Image.
The list of inserted images can be managed via the Set Cell Background Image toolbar button or the Cell Style Properties dialog.
type: Determines how paths are interpreted.
Images are drawn immediately after formula evaluation is complete.
=imageIf(P251 > 0, "e:\image_file1.png", "e:\image_file2.png", 1)
=imageIf(S10:S120 = 0, "folder1\music_file1.jpg", "image_file2.gif", 0)
2. messageIf(message, type, if_condition, reference-as-text)
Displays a message box with OK and Cancel.
message: Text to display.
type:
- 1 — information icon
- 2 — warning icon
- 3 — question icon
if_condition:
Message appears only if the condition evaluates to non‑zero.
reference (as text):
Optional full worksheet path.
If provided and you click OK, GS-Calc jumps to the referenced cell/range.
Messages appear immediately after formula evaluation is complete. You can use if_condition = 1 to signal the end of updating.
=messageIf("need to inspect this cell", 1, isError(folder2\sheet2!P251), "folder2\sheet2!P251")
=messageIf("need to inspect this cells", 1, isError(S120), "S121:S200")
3. playSoundIf(path, type, if_condition, loops, volume)
Plays MP3 and WAV files.
path:
File path.
- If type = 1: external disk file (e.g., e:\music_file1.mp3).
- If type = 0: full worksheet path of a file inserted via Insert > File.
type: Determines how the path is interpreted.
if_condition: File plays only if non‑zero.
loops:
Number of times to play.
-1 = endless loop.
volume:
Value from 0 to 1000.
Files play immediately after formula evaluation is complete. Use if_condition = 1 to signal the end of updating.
If multiple files are queued, they play sequentially.
To stop playback, press ESC or use Tools > Cancel Update.
=playSoundIf("e:\music_file1.mp3", 1, true, 1, 40)
=playSoundIf("folder1\music_file1.mp3", 0, true, 100, 80)
