Cell references can be written in either A1 notation or RC notation. The table below shows equivalent forms and explains what each reference points to.
| A1 notation | RC notation | Refers To |
| $A$1 | R1C1 |
A cell in row 1, column 1. This is an absolute reference: inserting/deleting rows or columns and copying/pasting does not change the reference. |
| A1 | R[0]C[0] R[1]C[2] R[-1]C[-2] |
A cell in row 1, column 1. This is a relative reference: inserting/deleting rows or columns and copying/pasting may adjust the reference to preserve correct relationships. Examples:
| $1:$1 1:1 |
R1 | The entire first row. |
| $A:$A A:A |
C1 | The entire first column. |
| $1:$5 | R1:R5 | Rows 1 through 5. |
| $A:$E | C1:C5 | Columns 1 through 5. |
| $A$1:$E$5 | R1C1:R5C5 | A rectangular range from A1 (top‑left) to E5 (bottom‑right). |
| Sheet1!$A$1 'Sheet1'!$A$1 |
Sheet1!R1C1 'Sheet1'!R1C1 |
The A1 cell from the “Sheet1” worksheet in the same workbook. Note:
| 'Folder1\Sheet1'!$A$1:$E$5 | "Folder1\Sheet1"!R1C1:R5C5 | The A1:E5 range from the “Folder1\Sheet1” worksheet in the same workbook. |
| 'Folder1'!$A$1 | "Folder1"!R1C1 | The A1 cell (returned as one column) from all worksheets in the “Folder1” folder. |
| 'Folder1'!$A$1:$E$5 | "Folder1"!R1C1:R5C5 | All A1:E5 ranges (returned as one column) from all worksheets in the “Folder1” folder. |
| 'd:\documents
\[sample.gsc]Sheet1'!$A$1 'd:\documents \[sample.gsc]Sheet1'!A1 |
"d:\documents \[sample.gsc]Sheet1"!R1C1 |
The A1 cell from “Sheet1” in the sample.gsc workbook. Note:
| "d: \[sample.gsc]Folder1"!$A$1:$E$5 | "d: \[sample.gsc]Folder1"!R1C1:R5C5 | All A1:E5 ranges (returned as one column) from all worksheets in the “Folder1” folder of the sample.gsc workbook. |
