GS-Calc (ver. 17 and later) can be configured to use functions written by users in C/C++ as plain DLL libraries. Such functions can even be used as a replacement for the default built-in functions. They can accept and return all the argument types and can also "return" images displayed directly in worksheets, or messages displayed after each update. Importantly, using these functions GS-Calc retains full multicore support along with the same speed and memory requirements (e.g. no extra arrays are allocated when passing ranges as arguments). You can add virtually any number of such functions.
Libraries are added with the Settings > Imported Function Libraries command, as shown in the screenshot below. The internal function names must match the original C/C++ names. The displayed names are what is entered in worksheet cells, and the only requirement is that they must be unique.
The added functions must be declared as
typedef double(__cdecl *DLL_EXT_FUNCTION)(GSCalcArg *arg);
where GSCalcArg is a structure enabling you to pass up to 15 arguments: numbers, strings and ranges/arrays.
struct ArrayItem
uint8_t type; // DLL_ARGT_EMPTY | DLL_ARGT_DOUBLE | DLL_ARGT_TEXT
uint8_t err_code; // ERROR1_DIV_BY_ZERO...ERROR1_SYNTAX_ERROR
uint16_t col; // [0, 4095]
uint32_t row; // [0, 12582911]
double num; // numeric cell
char text[MAXINPUT + 1];// text cell; max. 1024+NULL char. utf-8 string
typedef int(__cdecl *READ_ARRAY)(void *env, int array_index, ArrayItem *val);
typedef int(__cdecl *WRITE_ARRAY)(void *env, int array_index, ArrayItem *val);
typedef void* (__cdecl *MALLOC)(size_t s);
typedef void(__cdecl *MFREE)(void *_Memory);
struct GSCalcArg
uint8_t types[16]; // input: DLL_ARGT_NUMBER | DLL_ARGT_TEXT | DLL_ARGT_ARRAY | DLL_ARGT_EMPTY
// output: as above + DLL_ARGT_IMAGE | DLL_ARGT_MESSAGE
uint8_t errors[16]; // ERROR1_DIV_BY_ZERO...ERROR1_SYNTAX_ERROR
double numbers[16];
char *strings[16]; // input (UTF-8) 0...14 strings are preallocated by GS-Calc and must not be overwritten;
// strings[15] is used for output strings and already points to a MAXINPUT+1 char. temp. buffer
struct Dims
uint32_t cx;
uint32_t cy;
} array_dims[16]; // dimensions of the subsequent and grouped together range/array arguments passed from GS-Calc
struct
BYTE *data; // DIB data if you return types[15] = DLL_ARGT_IMAGE; must be (de-)allocated with memory_alloc/memory_free
size_t size; // DIB data size
Dims dims; // optional resizing when displaying the image (returned either as a DIB or a file path)
MALLOC memory_alloc;
MFREE memory_free;
} image;
READ_ARRAY read_array; // returns ArrayItem.type
WRITE_ARRAY write_array; // returns ArrayItem.type or -1 if the out-of-memory condition occurs
void *env; // internal data that must be passed back in read_array/write_array calls
Indices 0...14 in types[] and errors[] in GSCalcArg represent all subsequent argument types and errors from left to right passed from GS-Calc.
Indices 0...14 in numbers[], strings[] and array_dims[] point to argument values. The original parameters are already divided into these 3 groups (numbers, strings and ranges/arrays) when your function is called. For example, if a worksheet cell executes your function:
my_function(1.0, 2, "abc", a5:b15,)
the parameters passed to the DLL in the GSCalcArg structure will be as follows:
types[0] = DLL_ARGT_DOUBLE, types[1] = DLL_ARGT_DOUBLE, types[2] = DLL_ARGT_TEXT, types[3] = DLL_ARGT_ARRAY, types[4] = DLL_ARGT_EMPTY
numbers[0] = 1, numbers[1] = 2, strings[0] = "abc", array_dims[0] = {2, 10}
You can access numbers and strings directly. Array elements can be read (and written on output) using the read_array() and
write_array() functions, as shown below in the filter function example. The first argument is the
env internal pointer from the GSCalcArg structure, the second is the array index (0-14) as passed in array_dims[], and the last
is a pointer to the ArrayItem structure with the "col" and "row" of the requested element.
Note: for very large arrays, for best performance when reading data from or writing data to arrays, subsequent
read_array() and write_array() calls must access the array elements in left-to-right, top-to-bottom order.
On output, index 15 (DLL_ARGC_RET) is used to specify the returned type (in types[15]), the possible error code (in errors[15]) and the value (in numbers[15], strings[15] or array_dims[15]). The values types[15] and errors[15] must always be set correctly on return.
Note: strings[15] already contains a valid buffer (up to 1024 characters + NULL) allocated by GS-Calc, and if a given function returns a text value, it must be copied to that buffer as a NULL-terminated string.
// messageIf(condition, text)
// arguments:
// condition, message text
// returns:
// if condition != 0, 'messageIf' displays 'text' as a message box after each update/recalculation
// otherwise the message text is displayed in a cell as normal text
__declspec(dllexport) double __cdecl messageIf(GSCalcArg *arg)
uint8_t errorCode = 0;
if (arg->types[0] != DLL_ARGT_DOUBLE && arg->types[0] != DLL_ARGT_EMPTY || arg->types[1] != DLL_ARGT_TEXT)
errorCode = ERROR1_INVALID_VALUE;
if (arg->types[2] != DLL_ARGT_NONE) // more than 2 arguments detected
errorCode = ERROR1_SYNTAX_ERROR;
if (!errorCode && arg->errors[0])
errorCode = arg->errors[0];
if (!errorCode && arg->errors[1])
errorCode = arg->errors[1];
if (!errorCode)
::strncpy(arg->strings[DLL_ARGC_RET], arg->strings[0], 1024);
arg->strings[DLL_ARGC_RET][1024] = 0;
return arg->types[DLL_ARGC_RET] = (arg->numbers[0] ? DLL_ARGT_MESSAGE : DLL_ARGT_TEXT);
else
arg->errors[DLL_ARGC_RET] = errorCode;
return arg->types[DLL_ARGC_RET] = DLL_ARGT_EMPTY;
return 0;
// filter(range, column, number)
// arguments:
// range - a range/array
// column - column index (from 0 to the number of columns in 'range' - 1)
// number - numeric value to perform equality check
// returns:
// an array consisting of rows of 'range' containing 'number' in the specified column
__declspec(dllexport) double __cdecl filter(GSCalcArg *arg)
if (arg->types[0] != DLL_ARGT_ARRAY || arg->types[1] != DLL_ARGT_DOUBLE || arg->types[2] != DLL_ARGT_DOUBLE)
if (arg->types[3] != DLL_ARGT_NONE)
if (!errorCode && arg->numbers[0] >= arg->array_dims[0].cx)
if (!errorCode && arg->errors[2])
errorCode = arg->errors[2];
ArrayItem x = { 0 };
int outRow = 0;
for (uint32_t inRow = 0; inRow < arg->array_dims[0].cy && !errorCode; ++inRow)
x.row = inRow;
x.col = static_cast<uint16_t>(arg->numbers[0]);
if (arg->read_array(arg->env, 0, &x) == -1)
errorCode = x.err_code;
break;
bool match = false;
if (x.type == DLL_ARGT_DOUBLE)
match = (x.num == arg->numbers[1] || x.err_code && x.err_code == arg->errors[2]);
else if (x.type == DLL_ARGT_EMPTY)
match = (arg->numbers[1] == 0);
else
if (match)
for (x.col = 0; x.col < arg->array_dims[0].cx && !errorCode; ++x.col)
x.row = inRow;
arg->read_array(arg->env, 0, &x);
x.row = outRow;
// for best performance when writing to very large arrays, try to write in the left-to-right and top-to-bottom order
if (arg->write_array(arg->env, DLL_ARGC_RET, &x) == -1) // -1 means the out-of-memory condition or an invalid row/column
++outRow;
arg->errors[DLL_ARGC_RET] = (!outRow ? ERROR1_NULL_VALUE : 0);
return arg->types[DLL_ARGC_RET] = DLL_ARGT_ARRAY;
return 0;
// image(path, cx, cy)
// arguments:
// path - a bmp, jpg, png, gif file path
// cx/cy - display image size (optional)
// returns:
// loads an image (bmp, jpg, png, gif) from a disk and displays it, optionally resizing it
// to the cx/cy dimensions (in screen pixels)
__declspec(dllexport) double __cdecl image(GSCalcArg *arg)
if (arg->types[0] != DLL_ARGT_TEXT ||
arg->types[1] != DLL_ARGT_DOUBLE && arg->types[1] != DLL_ARGT_EMPTY ||
arg->types[2] != DLL_ARGT_DOUBLE && arg->types[2] != DLL_ARGT_EMPTY)
::strcpy_s(arg->strings[DLL_ARGC_RET], MAXINPUT, arg->strings[0]);
arg->image.dims.cx = static_cast<uint32_t>(arg->numbers[0]);
arg->image.dims.cy = static_cast<uint32_t>(arg->numbers[1]);
// arg->image.data must remain NULL
return arg->types[DLL_ARGC_RET] = DLL_ARGT_IMAGE;
Complete gsclib.h header file that must be included in each DLL project
A sample complete project with the messageIf, filter, image and fractal functions:
