Formatting: Using Data Styles and Numeric Formats
GS‑Base supports a variety of built‑in numeric styles, each with its own configurable options. These styles control how numbers, dates, times, percentages, fractions, and scientific values are displayed.
You can use the following standard numeric styles and their options:
Default
General
Currency
Accounting
Date
Time
Date/Time
Percent
Fraction
Scientific
2. User‑Defined Numeric Formats
You can define your own numeric formats by entering a custom style pattern in the Style dialog. Custom formats can be saved as new user styles for reuse.
To understand user‑defined formats, it helps to see how standard formats are constructed. For example, the accounting format is:
_(\$* #,##0.00_);"($"* #,##0.00\);_(\$* \-??_);_(@_)
A fraction format with a fixed denominator of 4 can be defined as:
?\ ?/\4
3. Conditional Formatting with Colors
User‑defined formats allow you to specify font colors for numbers that meet certain conditions. For example:
[green]#.#;[red]\-#.#;[blue]#.#;[gray]@
This displays:
Another example:
[red][<10]#0.00;[yellow][<=50]#0.0;[green][<400]##0;[magenta][>=400]#00
This displays:
Color values may be expressed as RGB values. For example:
[red][<10]#0.00 is equivalent to [#FF0000][<10]#0.00
You may also use one of the following predefined color names:
black[#000000]maroon[#800000]
green[#008000]olive[#808000]
navy[#000080]purple[#800080]
teal[#008080]gray[#808080]
silver[#C0C0C0]red[#FF0000]
lime[#00FF00]yellow;[#FFFF00]
blue[#0000FF]fuchsia[#FF00FF]
aqua[#00FFFF]white[#FFFFFF]
