Using AutoScroll Ranges
AutoScroll ranges allow you to define regions in which the current (selected) cell moves differently than in the rest of the worksheet when you press Enter or use the Left/Right or Up/Down arrow keys.
2. Horizontal Scrolling
Within an AutoScroll range, horizontal movement can be configured as follows:
3. Vertical Scrolling
Vertical scrolling works similarly:
4. Additional Options
Press Alt+Enter to quickly switch the active scrolling mode.
You can define multiple AutoScroll ranges and switch between them. To create and activate a range, select a cell range and choose Edit → Activate Autoscroll Range, or click the AutoScroll label on the worksheet toolbar. To deactivate the range, use the corresponding command.
You can also configure AutoScroll behavior globally for the entire worksheet in Settings → Options.
